ARC Raiders: Tempest Gun Guide - Printable Version
+--- Thread: ARC Raiders: Tempest Gun Guide (/showthread.php?tid=103483)
ARC Raiders: Tempest Gun Guide - Caitlyn - 01-20-2026
What is the Tempest and how does it perform?
The Tempest is a fully-automatic assault rifle with a moderate fire rate and accuracy. It uses medium ammo, has a magazine size of 25, and deals 10 damage per shot with a headshot multiplier of 1.5x. Its range is decent at 55.9 units, and stability is good at 78.9, making it manageable in sustained fire. Agility is 46, which means movement while aiming isn’t overly penalized, but stealth is low at 14, so it’s not a quiet weapon.
In practice, this means the Tempest is suited for mid-range engagements where you need a reliable weapon to apply consistent damage without excessive recoil. It’s not a sniper, and it’s not meant for extreme close quarters, but it does hold its own if you manage your positioning.
How do I get a Tempest?
There are two main ways to obtain the Tempest:
  1. Scavenging – You can find it in loot drops across missions. This is random, so don’t expect it to show up immediately.
  2. Crafting – Requires learning the Tempest blueprint. If you don’t already have it, some players choose to buy blueprints from other sources. For example, you can buy ARC Raiders blueprints fast delivery on U4N to skip the grind.
Crafting gives you more control over obtaining the weapon without relying solely on RNG drops.
What do I need to craft a Tempest?
Crafting a Tempest I requires:
  • 1× Magnetic Accelerator
  • 3× Medium Gun Parts
  • 2× Exodus Modules
You also need Gunsmith 3 and the Tempest blueprint. This is the base version; higher tiers must be upgraded from this first.
How does upgrading work?
The Tempest can be upgraded from level I to IV. Each upgrade improves recoil control, reload speed, and durability:
Upgrade
Ingredients
Gunsmith Req
PerksTempest II
Tempest I + 2 Advanced Mechanical Components + 1 Medium Gun Parts
1
16.6% Reduced Horizontal Recoil, 13% Reduced Reload Time, +10 Durability
Tempest III
Tempest II + 2 Advanced Mechanical Components + 3 Medium Gun Parts
1
33.3% Reduced Horizontal Recoil, 26% Reduced Reload Time, +20 Durability
Tempest IV
Tempest III + 2 Advanced Mechanical Components + 3 Medium Gun Parts
1
50% Reduced Horizontal Recoil, 40% Reduced Reload Time, +30 Durability
In practice, most players prioritize upgrading the Tempest for reduced recoil and faster reloads, which makes mid-range sustained fire more manageable.
How do I repair the Tempest?
Repairs are straightforward. Each level requires components to restore durability:
Version
Repair Cost
Durability RestoredTempest I
2× Advanced Mechanical Components + 2× Medium Gun Parts
+50
Tempest II
3× Advanced Mechanical Components + 3× Medium Gun Parts
+55
Tempest III
4× Advanced Mechanical Components + 4× Medium Gun Parts
+60
Tempest IV
5× Advanced Mechanical Components + 4× Medium Gun Parts
+65
Players often repair their Tempest between missions to avoid mid-battle breaks. Having spare parts on hand helps prevent downtime.
Can I recycle or salvage it?
Yes. Recycling and salvaging are slightly different:
  • Recycling returns more advanced components and medium gun parts.
  • Salvaging mainly returns medium gun parts.
For example, Tempest I gives 2 advanced mechanical components and 2 medium gun parts when recycled, and 2 medium gun parts when salvaged. This is useful if you want materials for crafting other weapons or upgrades.
Should I sell my Tempest or its components?
Sale prices vary depending on weapon level. If inventory management is a concern, component sale value per slot is often higher than the weapon sale price:
Version
Weapon Sale Price
Component Sale Price Per SlotTempest I
13,000
4,367
Tempest II
17,000
4,325
Tempest III
22,000
5,725
Tempest IV
27,000
7,125
Players usually keep upgraded Tempests for personal use and only sell lower-level versions if they need coins. Always check the component resale value; sometimes dismantling and selling parts is more profitable than selling the full weapon.
Practical tips from experience
  1. Ammo management – The Tempest uses medium ammo, which can run out quickly in prolonged fights. Always keep a spare magazine or stockpile medium ammo.
  2. Upgrade early – Reducing recoil and reload time makes the Tempest far easier to use in real combat. Most players notice a significant improvement at Tempest III.
  3. Positioning – Since stealth is low, avoid rushing enemies directly. Use cover and engage at mid-range where accuracy and stability shine.
  4. Combine with perks – Focus on perks or armor that improve your agility or reduce recoil further, complementing the weapon’s strengths.
The Tempest is a reliable, mid-range assault rifle that performs well in most standard combat scenarios. While it’s not specialized, its upgrades and stability make it versatile enough for general use. Knowing how to craft, upgrade, repair, and recycle it efficiently will make it a consistent part of your loadout. For players who don’t want to wait for blueprint drops, options like buying ARC Raiders blueprints fast delivery on U4N can save time and let you get started quickly.
Overall, the Tempest rewards careful handling and mid-range play. Keep it upgraded, manage ammo, and use positioning to get the most out of this epic assault rifle.
Strategy Insight:  Arc Raiders Pulse Mine: How to get & best uses
