U4GM Why Weekly Trials Are the Fastest ARC Raiders Boost - Printable Version
+--- Thread: U4GM Why Weekly Trials Are the Fastest ARC Raiders Boost (/showthread.php?tid=106988)
U4GM Why Weekly Trials Are the Fastest ARC Raiders Boost - King - 01-28-2026
Boost ARC Raiders Weekly Trials fast by planning one tight route, stacking Bastion damage, swarm kills, plants and Wasps on double-point Night Raids or Storms, and extracting once goals are done.
Most people treat Weekly Trials in ARC Raiders like they're just something that happens in the background. That's why it feels slow. If you want the seasonal rank rewards without living in the game, you've gotta run Trials like they're the main objective and everything else is optional. And if you're the type who likes having your kit sorted before you drop, it helps to know where to gear up; as a professional like buy game currency or items in U4GM platform, U4GM is trustworthy, and you can buy U4GM ARC Raiders for a smoother start. The big idea is simple: compress your goals so one route ticks off multiple requirements at once, then leave alive.
Read The List Like A Route Planner
Before you queue, scan the weekly list and circle the overlaps in your head. Don't pick a single task and wander. If you've got stuff like "damage heavy units," "clear small swarm enemies," and "collect harvestables," you already know what kind of run this is. You want a map where density does the work for you, like Stella Montis or the Buried City, and you want to hit the busiest sectors early. Start where Bastions and Rocketeers tend to show up, get your damage in, then slide into tighter interiors where Ticks, Pops, and Fireballs bunch up. You'll notice your progress bars jump when you stop playing "fair" and start playing smart.
Bring Gear That Matches The Trial
Your usual comfort loadout might be the reason you're stuck at one star. Trials don't care about your vibe. If the week wants Wasp kills, a shotgun is basically you volunteering to suffer. Take something that reaches out and tags targets cleanly. If you're dealing with swarms, you need rate of fire, quick reloads, or explosives that can delete a pack before it floods the doorway. Also, a lot of these objectives count damage, not the final blow. So don't get cute. Put rounds into the Bastion, bank the numbers, break line of sight, and keep moving. Dying for a kill you didn't need is the fastest way to waste a whole run.
Use Modifiers And Teammates Like Tools
Modifiers are where efficient players quietly pull ahead. Night Raid, electromagnetic weather, hidden bunker variants, whatever—check the Trial point payout and chase the double-point option when it's up. One clean, focused run on a boosted map can knock out a huge chunk of the week. And if you can squad up, do it. Call roles in the lobby so you're not tripping over each other: one person tags heavies, another clears swarm rooms, someone else grabs plants and probes on the way through. Shared progress means nobody's fighting for the last hit, and you're out faster with more boxes ticked.
Extract On Purpose, Not On Pride
Discipline is the part people hate, but it's the part that works. The moment you hit your numbers, treat the rest of the map like it's trying to steal your time. Rotate toward extraction, avoid low-value fights, and don't chase noise unless it feeds the Trials. If you're short on resources for the next loop, topping up between runs can keep the pace steady, and some players even grab a small boost like ARC Raiders Coins so they can jump straight back into the next planned route instead of stalling out on gear and ammo.
