U4GM How to Build the Best ARC Raiders Skill Tree - Printable Version
+--- Thread: U4GM How to Build the Best ARC Raiders Skill Tree (/showthread.php?tid=137588)
U4GM How to Build the Best ARC Raiders Skill Tree - King - 04-01-2026
ARC Raiders skill tree guide: prioritise stamina, crouch speed and faster looting first, then add shield or weight perks to match your build for safer, more profitable runs.
One of the first lessons ARC Raiders teaches you is that a bigger gun doesn't fix bad movement. You can hit hard and still lose your haul because you ran out of stamina at the wrong time or got caught rummaging through a crate for too long. That's why early progression matters more than people think. If you're serious about smoother runs, better extracts, and building momentum without wasting hours, it helps to think about efficiency first, not brute force. Plenty of players also look at outside resources like U4GM when they want a faster start with game currency or useful items, but your skill points still decide how comfortable each raid actually feels.
Build your base around movement
In the opening stretch, Mobility and Survival give you the most value. It's not flashy, but it works. Youthful Lungs and Marathon Runner make a difference almost right away. You'll feel it during longer routes, especially when you need to break line of sight and keep going. Agile Croucher is another one that doesn't sound amazing on paper, yet in actual matches it's brilliant. Crouch movement becomes much less painful, and that matters when you're trying to stay low around patrols or sneak past another squad. A lot of new players ignore these perks because they want combat power first. Usually they regret it a few hours later.
Loot faster and stay out of trouble
Then there's the scavenging side, which honestly wins more runs than clean gunplay does. Looter's Instincts is one of those perks you notice every single session. The less time you spend standing still in front of containers, the better. Revitalizing Squat adds another layer because it lets you recover while staying tucked away instead of exposing yourself on the move. Silent Scavenger is worth grabbing early too. ARC alarms can turn a tidy loot route into a complete mess, and quieter breaching helps stop that spiral before it starts. Add Proficient Pryer later and those awkward pauses at doors or containers become much shorter, which is exactly what solo players need.
Heavy setups need support
Once your foundation feels right, that's when Conditioning starts making more sense. If you like carrying bulkier weapons, stronger shields, or just playing a louder style, you can't really skip it forever. Used to the Weight and Loaded Arms help smooth out the drag from heavier gear, and without them your whole setup can feel sluggish. That said, going all in on tanky perks too early usually backfires. You end up surviving a little longer in fights, sure, but getting to those fights feels worse. Most experienced players land somewhere in the middle. Enough Mobility to reposition. Enough Conditioning to avoid folding the second things get scrappy.
Match the tree to your actual kit
The nice part is that ARC Raiders doesn't punish experimentation too hard. Respeccing is cheap enough that you can test things, drop what feels useless, and shape the board around how you really play instead of how you thought you'd play. That's the bit people miss. A perk isn't good just because it sounds good. If it doesn't make your routes cleaner, your looting safer, or your combat less awkward, it's probably not pulling its weight. If you're still figuring out your preferred style, even browsing options like ARC Raiders Accounts can give you a sense of different loadout paths, and from there it gets much easier to build a raider that actually feels right in the field.
