U4GM ARC Raiders Free Cosmetics Tips via Twitch Drops - Printable Version
+--- Thread: U4GM ARC Raiders Free Cosmetics Tips via Twitch Drops (/showthread.php?tid=155903)
U4GM ARC Raiders Free Cosmetics Tips via Twitch Drops - King - 05-06-2026
Unlock free ARC Raiders cosmetics through Twitch Drops by linking your Embark ID, watching eligible streams, and claiming limited-time backpack charms before the event ends.
One of the nicest things about ARC Raiders right now is that it doesn't feel like it's trying to squeeze players at every turn. A lot of shooters lock the fun cosmetic stuff behind a paywall, then ask for more every season. Here, that pressure just isn't the same. You can earn outfits, loadout flair, and even the small decorative bits through normal play, which already makes the game easier to enjoy. If you're the type who likes collecting everything, that matters. And if you also keep an eye on gaming deals or item services through places like U4GM, it's still refreshing to see a game where cosmetics don't feel completely out of reach unless you spend money.
What the current Twitch Drops give you
The active Twitch Drops campaign tied to the Riven Tides update started on April 28 and runs until May 26, 2026. It's a simple setup, which is probably why so many players are bothering with it. Watch one hour of eligible ARC Raiders streams and you'll unlock the Floppy Disk backpack charm. Hit two total hours watched and the Buoy charm gets added as well. That's it. No weird milestones. No need to sit through one long stream either. You can watch for a bit one night, switch to another creator the next day, and still make progress. For busy players, that's honestly the best part. You don't have to plan your week around it.
Getting your account ready
Before you start farming watch time, make sure your Twitch account is linked to your Embark ID. If it isn't, those hours may not count, and that's where people usually get caught out. Head into Twitch settings, open the connections section, and sync the account properly. It only takes a few minutes, but skipping it can waste the whole campaign. After that, look for ARC Raiders streams with the Drops Enabled tag. Most people just leave a stream running in the background while they work or play something else. That works fine, though it's worth checking now and then that Twitch is still tracking progress like it should.
Common mistakes players keep making
A lot of players assume the rewards will appear in-game automatically once the watch time is done. They won't. You need to open your Twitch Drops inventory and claim each reward manually. Miss that step and nothing shows up, even if the hours are complete. If you've claimed everything and the charms still aren't in your inventory, restart the game client first. That fixes it more often than not. It's also smart to claim rewards before the event ends, not days later when you suddenly remember. Twitch may hold unclaimed items for a while, but leaving it too late is asking for trouble.
Why this event is worth doing
For a couple of passive viewing hours, these Drops are an easy win. They add a bit of personality to your gear, they don't ask for any real grind, and there's a good chance they'll stay exclusive after the campaign ends. That's what makes them worth grabbing now instead of putting it off. If you're already spending time around the game's community, you may as well get something from it, and players looking for extra help outside the usual route often check services like ARC Raiders Boosting while they sort out the rest of their progress in game.
