U4GM - 10 Essential Endgame Items in Elden Ring: A Complete Guide - Printable Version
+--- Thread: U4GM - 10 Essential Endgame Items in Elden Ring: A Complete Guide (/showthread.php?tid=59707)
U4GM - 10 Essential Endgame Items in Elden Ring: A Complete Guide - Caitlyn - 05-29-2025
Reaching the endgame in Elden Ring is a rewarding but brutal experience. By the time you get to the Mountaintops of the Giants, Haligtree, and beyond, the game expects you to be fully equipped—mentally and materially. Having played through Elden Ring multiple times, I’ve learned the hard way that having the right Elden Ring items can make the difference between repeated failure and triumphant victory.
This guide covers the 10 essential items you’ll want to secure for a smoother endgame journey. If you’re running short on time or don’t feel like scouring every dungeon and mountaintop, you can also buy Elden Ring item delivery service to get what you need instantly and keep the momentum going.
1. Mimic Tear Ashes
Hands down one of the most powerful Spirit Ashes in the game. It summons a duplicate of yourself, complete with weapons, armor, and spells. Especially useful in solo play when facing late-game bosses like Malenia or the Elden Beast.
Personal tip: I relied on the Mimic Tear heavily in my first playthrough. It felt like having a true co-op partner who knew my build perfectly.
2. Blasphemous Blade
For Strength/Faith hybrid builds, this weapon offers unmatched healing and damage return. Its unique skill restores HP on hit, which becomes a game-changer in prolonged fights.
My experience: I used this blade in NG+ and found I barely needed to heal during open-world exploration. It's a top-tier weapon for survivability.
3. Lord of Blood’s Exultation
This talisman boosts attack power when blood loss occurs nearby. It synergizes incredibly well with bleed builds using weapons like Rivers of Blood or Ghiza’s Wheel.
Advice: If you’re running bleed, this talisman is non-negotiable. I paired it with Swarm of Flies and watched enemies melt in seconds.
[/url]
[url=https://www.u4gm.com/elden-ring-items][Image: e2e4a9faa6369be28bcf21e78ceb7138.jpg]
4. Erdtree’s Favor +2
An endgame talisman that boosts HP, stamina, and equip load. Found in Leyndell, Ashen Capital, it’s a universal pick for any build.
Note from my run: This was one of the last items I picked up before facing the final boss, and the extra survivability made a noticeable difference.
5. Godrick’s Great Rune
While not exclusive to the endgame, it remains one of the best overall runes, boosting all attributes. Once activated with a Rune Arc, it helps push your stats to endgame levels.
Personal story: Even in late-game PvP and invasions, Godrick’s Rune gave me the versatility I needed to adapt to different enemy strategies.
6. Ancient Dragon Smithing Stones
These rare upgrade materials are needed to max out weapons to +10. They’re scattered across late-game zones like Farum Azula and Haligtree.
Tip: These are limited, so choose wisely. I usually use my first one on my boss weapon of choice and farm others cautiously—or buy Elden Ring item delivery service to avoid the grind.
7. Crimsonwhorl Bubbletear
This Physick mix-in converts damage received into health for a short time. It’s extremely valuable during phase transitions in difficult boss fights.
My use: I saved this for Malenia’s second phase, and it saved me from what would’ve been a lethal Scarlet Aeonia blast.
8. Dragoncrest Greatshield Talisman
Provides massive physical damage negation, which is vital in endgame areas filled with aggressive enemies. A must-have for tanky or melee-focused builds.
Personal experience: Combined with high poise armor, this talisman helped me stand toe-to-toe with the most brutal enemies without flinching.
9. Black Knife Tiche
A powerful Spirit Ash that applies the Destined Death debuff, reducing max HP of enemies. She’s highly effective in boss fights, even outperforming Mimic Tear in some cases.
My perspective: I found Tiche particularly useful against bosses with healing phases or high HP pools. Her consistency made her a key summon in NG+.
10. Malenia’s Great Rune
When activated, it restores HP with every hit you land. It’s a high-risk, high-reward option for aggressive players. Not easy to get, but incredible once in hand.
Caution from experience: Make sure you have a fast-hitting weapon or bleed build to take full advantage of this rune. I paired it with Twinblades for maximum effect.
Endgame in Elden Ring doesn’t pull any punches. These ten Elden Ring items are the ones I consider truly essential after spending hundreds of hours exploring every corner of the Lands Between. Whether it’s making a final boss more manageable or giving your build that last 10% edge, each item listed above offers strategic advantages you don’t want to overlook.
And if you’d rather avoid the late-game item hunt and prep instantly, consider using a reliable buy Elden Ring item delivery service. Services like U4GM can save hours of farming and let you focus on the content that matters most to you.
New Strategy: [font=Arial, sans-serif, -apple-system, BlinkMacSystemFont, "Segoe UI", Roboto, Oxygen-Sans, Ubuntu, Cantarell, Neue, sans-serif]The Role of Elden Ring: Object and Metaphor for the State of the World[/font]
