Underrated But Profitable—Hidden Currency Farming Routes - Printable Version
+--- Thread: Underrated But Profitable—Hidden Currency Farming Routes (/showthread.php?tid=61934)
Underrated But Profitable—Hidden Currency Farming Routes - ShadowRift - 08-05-2025
In Path of Exile 2, most players chase after obvious farming routes like high-tier maps or endgame bosses. But if you're looking for underrated yet profitable ways to earn PoE 2 currency, there are hidden gems that many overlook. These routes can be incredibly rewarding, especially if you’re just starting out or want to avoid competition in the economy.
One of the most consistent but underrated methods is Delve farming in early darkness zones. Many players rush to deep layers for rare encounters, but shallow areas—between depth 20–60—often contain currency nodes that drop Chaos Orbs, Fusing Orbs, and even Exalted Orbs. They also require less investment in flares and dynamite. Focus on fractured walls for hidden chests and prioritize currency or fossil nodes. These areas reset quickly and are easy to run if your build has good movement speed.
Another solid method is low-level Heist contracts. Many players only run high-level blueprints, but early contracts are fast, low-risk, and can drop stacks of Rogue’s Markers, currency shards, and valuable base items. The trick here is volume. Run them fast, stack up loot, and sell what you don’t need. If you pick up the Gianna rogue early, she reduces blueprint reveal costs, making later profits even better. Heists also drop PoE 2 currency like Alteration Orbs, Regal Orbs, and Chaos Orbs at a decent rate.
One more hidden trick: Beastcrafting currency from Einhar’s Menagerie. Many players ignore beast captures, but the recipes to add modifiers or duplicate items often require cheap beasts and can turn regular gear into valuable rares. For example, the beast recipe to “add a Mod to a Rare Item” can turn a mediocre weapon into something worth several Chaos Orbs. It's a smart way to indirectly buy PoE 2 currency through crafting, since you’re increasing item value with minimal cost.
You can also farm Expedition logbooks from zones that spawn Gwennen or Rog. These two vendors can be used to reroll items or gamble for unique gear, both of which can be turned into big profits. Running early Expedition areas can drop valuable runed artifacts, and selling logbooks can earn you PoE 2 currency fast if you don’t want to run them yourself.
A great place to get ahead with these methods is U4GM. Many players buy PoE 2 currency there to get a boost before diving into farming routes. This allows you to test builds, try new strategies, or flip valuable items without grinding for hours.
In short, you don’t need to farm only high-end content to make good currency. With these hidden strategies—Delves, early Heists, beastcrafting, and Expedition—you can steadily grow your wealth in PoE 2. These routes are low-competition, beginner-friendly, and highly profitable when done right. So next time you log in, skip the obvious and start exploring the hidden paths.
Recommended Article:Path of Exile 2 Update 0.3.0 Content Preview
