This Hidden Map Has Insane PoE 2 Currency Drop Rates! - Printable Version +- Mr Baddeley 3d Printed Droids Forum (https://forum.mbprinteddroids.com) +-- Forum: My Category (https://forum.mbprinteddroids.com/forumdisplay.php?fid=1) +--- Forum: My Forum (https://forum.mbprinteddroids.com/forumdisplay.php?fid=2) +--- Thread: This Hidden Map Has Insane PoE 2 Currency Drop Rates! (/showthread.php?tid=62599) |
This Hidden Map Has Insane PoE 2 Currency Drop Rates! - ShadowRift - 08-19-2025 If you have been playing Path of Exile 2 for a while, you probably know how important PoE 2 currency is. It’s the backbone of the game, letting you trade, craft, and power up your character. Recently, I stumbled upon a hidden map that has given me some of the craziest currency drops I’ve ever seen, and I want to share this with you so you can take advantage of it too. The map I’m talking about is tucked away in the mid-tier regions, but it shines because of its monster density and special modifiers. When you enter this map, you’ll notice the number of rare monsters is way higher than usual. That’s the key—rare monsters drop more valuable loot, and in PoE 2, that means a better chance at getting Chaos Orbs, Divine Orbs, and even Exalted Orbs. These are some of the most popular PoE 2 currency items that players are always looking for. Here’s a strategy that worked perfectly for me: before entering the map, make sure you have a build that clears fast. Speed is everything here because monsters respawn quickly. I also recommend using Scarabs or Sextants if you have them. These items can juice up your map and make the drops even crazier. In one run, I managed to collect multiple Chaos Orbs, a couple of Divine Orbs, and even fragments that later helped me open higher-tier maps. Another important trick is to save your loot filter settings for this specific map. Because the currency drop is so high, your screen can get flooded with items. A clean filter helps you focus on what really matters: PoE 2 currency. I even had to make space in my stash tabs before running this map because I knew it would be packed with drops. Now, some of you might not have the patience to grind for hours, and that’s fine. Many players choose to buy PoE 2 currency instead, which can save a lot of time. I personally tried u4gm once for this, and the process was simple and quick. But if you enjoy farming like me, this hidden map is definitely worth exploring. To maximize your profits, run this map in groups if you can. More players mean more monster health, but it also means more loot overall. If you’re solo, it’s still very rewarding, but a party can make it even more fun. In short, if you’re looking to stockpile Chaos Orbs, Divine Orbs, or even the rare Exalted Orb, this hidden map is one of the best farming spots I’ve found so far. Whether you want to grind it out yourself or buy PoE 2 currency when you’re short on time, building up a strong stash will make your journey through PoE 2 much smoother. Try this farming route and you’ll see why I call it insane! |
