Ranking the best item slots to use an Arcanist’s Etcher on - Printable Version
+--- Thread: Ranking the best item slots to use an Arcanist’s Etcher on (/showthread.php?tid=72731)
Ranking the best item slots to use an Arcanist’s Etcher on - ShadowRift - 11-15-2025
When you start playing Path of Exile 2, you’ll quickly learn that some items are simply better targets for an Arcanist’s Etcher than others. Because this tool can lock in powerful modifiers, choosing the right slot matters a lot—especially when PoE 2 currency is valuable and you don’t want to waste it. Many new players who want to buy PoE 2 currency often ask which item slots give the biggest payoff, so here is an easy, kid-friendly guide loaded with real tips and simple-to-follow strategies. And yes—we’ll mention u4gm just once as requested.
[Image: Spongebob-2.webp]
Why Item Slot Matters
Think of each item slot like a treasure chest. Some chests can hold bigger treasures. Some can only hold small treasures. Using an Arcanist’s Etcher on the biggest treasure chests gives you the most value. This is also why many players save their PoE 2 currency for the best slots.
Best Slot #1: Weapons (Two-Handed First)
Two-handed weapons are the number one place to use an Arcanist’s Etcher. They have:
  • More mod slots
  • Stronger base stats
  • A huge impact on your damage
A single locked-in mod here can increase your damage by a lot. If you find a weapon with a high-tier “Increased Damage,” “Added Flat Damage,” or powerful caster stats, locking that mod early lets you build a monster weapon later. This saves tons of PoE 2 currency and lets you invest smarter instead of rerolling endlessly.
Practical Tip:
Before using the Etcher, always check if the base weapon is good. Don’t etch a bad base. Aim for high-level bases with strong implicit mods.
Best Slot #2: Amulets
Amulets offer some of the most powerful prefixes and suffixes in the entire game. They can boost damage, attributes, resistances, and even give special utility bonuses.
Why they’re amazing:
  • Tons of build-defining mods
  • Big value per craft
  • They stay useful for many levels
If you have a great amulet with a single very strong mod—like “+All Attributes,” “% Spell Power,” or top-tier life—you can lock it safely. This is a slot where people often choose to buy PoE 2 currency because crafting amulets can get expensive.
Best Slot #3: Rings
Rings might look small, but they carry big bonuses. Good rings can fix your resistances, boost damage, add life, or even help you cap important mechanics like accuracy or mana. Because rings affect so many parts of your build, locking a strong mod early is a smart and efficient move.
Pro Tip:
If you find a ring with “Chaos Resist,” “High Life,” or “High Attribute rolls,” that’s a perfect candidate for using the Etcher.
Good Secondary Slot: Belts
Belts don’t usually beat weapons or jewelry, but they’re still good targets, especially if you get strong life or flask mods. Locking a high-tier life roll makes the rest of your belt crafting much easier.
What NOT to Waste the Etcher On
Even with lots of PoE 2 currency, don’t use an Etcher on the following:
  • Low-level items
  • Weak bases
  • Items with only “okay” mods
    These don’t give long-term value. Always choose items that will stay strong for many chapters.
Simple Crafting Path for New Players
Here is a beginner-friendly plan even a kid could follow:
  1. Find a strong mod on a weapon, amulet, ring, or belt.
  2. Check the base. Make sure it’s high level.
  3. Use the Arcanist’s Etcher to lock the best mod.
  4. Upgrade the item slowly using common PoE 2 currency like
    • Transmutation Orbs
    • Alchemy Orbs
    • Binding Orbs
    • Fusing Orbs
  5. Save rare crafting currency until the item is nearly done.
  6. If you need extra materials, use a trusted shop like u4gm just once to top up.
[*]The best use of an Arcanist’s Etcher is on items that can grow with your character. Weapons, amulets, and rings give the biggest long-term value. Belts are solid backup targets. Always think: “Will this item still be good 10 levels later?” If yes, it’s a great choice.
[*]If you follow these simple steps, you’ll save a lot of PoE 2 currency, craft smarter, and make your character much stronger without wasting materials.
