Best Weapons and Gear for BO7 Season 1 Warzone - Printable Version +- Mr Baddeley 3d Printed Droids Forum (https://forum.mbprinteddroids.com) +-- Forum: My Category (https://forum.mbprinteddroids.com/forumdisplay.php?fid=1) +--- Forum: My Forum (https://forum.mbprinteddroids.com/forumdisplay.php?fid=2) +--- Thread: Best Weapons and Gear for BO7 Season 1 Warzone (/showthread.php?tid=84077) |
Best Weapons and Gear for BO7 Season 1 Warzone - Jimekalmiya - 12-09-2025 Black Ops 7 has integrated with Call of Duty: Warzone for Season 1, adding the full BO7 weapon pool and attachments into the battle royale. While you can still use weapons from the last few years, the most powerful options are going to be the new Black Ops 7 guns. In this guide, we'll provide some recommended weapon builds for Warzone in Season 1 of Black Ops 7. MXR-17 The MXR-17 is a powerful and easy-to-use assault rifle for long-range fights in Warzone. The recommended attachments will boost the gun's damage range, bullet velocity, and increase ammo count. The Greaves AccuSpot 3X is a great optic for most long-range builds, but if you're playing small map Resurgence and don't want the bigger scope, you can swap this out for something simple and clean like the Lethal Tools ELO. Recommended MXR-17 attachments: Optic: Greaves AccuSpot 3X Muzzle: Monolithic Suppressor Barrel: 17" Greaves Scourge Barrel Magazine: Rhodes Drum Mag Stock: Winch Stock MK.78 The MK.78 light machine gun is a heavy-hitting, long-range option for Warzone. The recommended attachments will help you reduce the gun's recoil, making this much more manageable to use at range. The recommended magazine is a Prestige attachment, so you might not have this unlocked yet, but it's a very impactful attachment for improving mobility and reducing recoil. You can substitute the Gravepack Extended Belt if needed to simply boost the ammo count until you unlock it. Recommended MK.78 attachments: Optic: Greaves AccuSpot 3X Muzzle: RL-7.62 Compensator Barrel: 25" EAM Heavy Barrel Underbarrel: Bowen Sentry Foregrip Magazine: MFS Heatshield Belt Fed X9 Maverick The X9 Maverick is a three-round burst assault rifle with high damage, and it can be a powerful choice for long-range fights. The recommended attachments will greatly boost the gun's damage range and bullet velocity, as well as improve the aim-down-sight speed. Recommended X9 Maverick attachments: Optic: Greaves AccuSpot 3X Muzzle: Monolithic Suppressor Barrel: 16" OS-Density Barrel Rear Grip: Pillory Grip Fire Mods: 4.73 Caseless Overpressured DS20 Mirage The DS20 Mirage assault rifle is another solid pick for assault rifles in Black Ops 7, but this gun also has a great build for a sniper support class. The recommended attachments will boost the ammo count, reduce recoil, and improve movement speed to make this gun work great for close to medium-range fights. Recommended DS20 Mirage attachments: Optic: Lethal Tools ELO Muzzle: Redwell 5.56 Compensator Magazine: Andean Extended Mag Stock: Assault Division Stock Fire Mods: Recoil Sync Unit MPC-25 The MPC-25 submachine gun doesn't feel very powerful in multiplayer, but it's a powerful gun with a fast time-to-kill in battle royale. The recommended attachments will help reduce a lot of the weapon's recoil, and it will also boost the ammo count. This recommended build includes an optic for cleaner sights, but if you don't mind the iron sights, it's worth swapping the optic for the 14.5" VAS Ashe Barrel for an increase to the damage range. Recommended MPC-25 attachments: Optic: Lethal Tools ELO Muzzle: K&S Brake-28 Underbarrel: VAS Drift Lock Foregrip Magazine: Sustain-25 Extended Mag Fire Mods: Recoil Sync Unit Kogot-7 Season 1's new Kogot-7 submachine gun is another solid choice for close-range combat in battle royale. The Kogot-7 does have a bit of recoil, but the recommended attachments will work to reduce quite a bit of the gun's kick. Recommended Kogot-7 attachments: Muzzle: Hawker Series 45 Barrel: 13.5" Canis-05 Barrel Underbarrel: Vas Drift Lock Foregrip Magazine: Vex Expanse Mag Fire Mods: Buffer Springs VS Recon The VS Recon is a deadly bolt-action sniper rifle, and this is a popular choice for sniping in Season 1. The recommended attachments will increase the damage range and bullet velocity, and also reduce some of the weapon's kick. The recommended underbarrel attachment is a Prestige attachment, so you might not have unlocked this yet, and you can substitute it for the Stetig-C Handguard if needed. Recommended VS Recon attachments: Muzzle: Monolithic Suppressor Barrel: 23" G-Force Barrel Underbarrel: MFS R-Stop Handguard Rear Grip: R-1 Shelf Grip Fire Mods: 7.62 NATO Overpressured That is all you need to know about Best Loadouts In Warzone For BO7 Season 1! For more info, please visit U4GM. Aslo, you can buy bot lobbies bo7 here, 100% safe! Thes lobbies will help you unlock edge in Call of Duty: Black Ops 7! |
