Aion 2 Guide: Splendent Horned Dragon Lord Bow Stats and Tips - Printable Version +- Mr Baddeley 3d Printed Droids Forum (https://forum.mbprinteddroids.com) +-- Forum: My Category (https://forum.mbprinteddroids.com/forumdisplay.php?fid=1) +--- Forum: My Forum (https://forum.mbprinteddroids.com/forumdisplay.php?fid=2) +--- Thread: Aion 2 Guide: Splendent Horned Dragon Lord Bow Stats and Tips (/showthread.php?tid=91522) |
Aion 2 Guide: Splendent Horned Dragon Lord Bow Stats and Tips - IndigoFable - 12-25-2025 If you’ve been playing Aion 2 as a Ranger, you’ve probably heard about the Splendent Horned Dragon Lord Bow. It’s one of the more talked-about bows among Asmodians due to its strong stats and crafting potential. In this guide, I’ll break down how it works in practice, how most players use it, and what to expect when you obtain it. What Makes the Splendent Horned Dragon Lord Bow Special? The Splendent Horned Dragon Lord Bow is a Heroic-level bow that requires level 45 to equip. Its item level is 114, and it comes with some solid base stats: Attack: 446 ~ 561 Accuracy: 100 Critical Hit: 100 PvE Damage Boost: 5% Magic Stone Slots: 5 Divine Stone Engraving Slot: 1 Most players appreciate it for a few reasons. First, its attack range is quite high for its level, which means it can deal consistent damage in PvE situations. Second, the bow is enchantable up to +20 and can exceed up to 5 times, giving long-term growth potential. Finally, it is both tradable and storable, so you don’t lose much flexibility in managing your inventory. How Do Players Usually Obtain It? In general, the Splendent Horned Dragon Lord Bow is crafted rather than dropped. Crafting requires gathering materials and having a sufficient crafting skill level. Most players who focus on crafting or have access to a guild with crafting support find it easier to obtain than trying to farm rare drops. A common practice is to imprint the bow’s soul. When you first imprint its soul, it grants six additional abilities that significantly enhance combat performance. These abilities usually boost attack, precision, and critical stats, making the bow more effective in both PvE and PvP. For those who want convenience, some players turn to the U4N Aion 2 items shop – great prices for acquiring materials or pre-crafted items. While it’s not necessary, it can save time if you want to skip the grind. What Are the Main Stats in Practice? While the raw numbers look good on paper, here’s how they usually play out: Attack (446~561) – Most players notice that the higher attack range makes solo farming or grinding events faster. The bow hits hard even on moderately armored mobs. Accuracy (100) – Accuracy ensures that your shots land consistently. In PvP, this is especially useful against mobile or evasive enemies. Critical Hit (100) – The crit rating gives a noticeable boost in damage, making it easier to burst targets quickly. PvE Damage Boost (5%) – It may seem small, but for long farming sessions or dungeon runs, this can add up. Additional stats gained from soul imprinting, like Might, Precision, Critical Attack, and Back Attack, make the bow very reliable for endgame PvE or casual PvP encounters. How Do Enchants and Exceeds Work? Enchanting and exceeding are core parts of weapon progression in Aion 2. The bow can be enchanted up to +20, which increases your base attack and secondary stats. Exceeding up to 5 times further boosts its effectiveness, although this requires specific items and carries some risk of failure. Most players prioritize enchanting first because the gains are steady and predictable. Exceeding is usually reserved for high-end PvE or serious PvP players who want maximum damage potential. What About Combat Performance? In practical gameplay, here’s what you can expect: Combat Speed: 13.8% ~ 15.9% Status Effect Chance: 23% ~ 26.5% Multi-hit Chance: 9.8% ~ 11.3% Critical Attack: 52 ~ 67 Back Attack: 52 ~ 67 Block: 57 ~ 73 Weapon Damage Boost: 14.9% ~ 17.2% These numbers indicate that most players can rely on the bow for consistent DPS. Its high multi-hit and critical stats make it particularly strong in sustained fights, while back attack bonuses favor flanking or positioning strategies in PvP. Is the Bow Worth It for All Players? It depends on your playstyle. Most casual players find that the bow gives solid PvE performance without needing excessive investment. Hardcore PvP players can benefit from soul imprinting and max enchant levels to maximize damage output. If you’re mostly focused on crafting or soloing content, the bow’s high base stats and the extra abilities from soul imprinting make it very practical. On the other hand, players who enjoy competitive arena play may need to pair it with specific gear sets to fully take advantage of its potential. Tips From Experienced Players Focus on soul imprinting early – The additional abilities often make a bigger impact than initial enchant levels. Upgrade gradually – Enchanting in small increments reduces the risk of losing progress. Use positioning in PvP – The bow’s back attack and multi-hit stats favor strategic placement over just raw attack. Plan crafting materials – Gathering ingredients in advance will save time and make crafting less stressful. Check item shops if needed – Sometimes it’s more efficient to supplement crafting with shop resources like U4N Aion 2 items shop – great prices, especially for rare materials. Conclusion The Splendent Horned Dragon Lord Bow is a versatile and strong choice for Asmodian Rangers in Aion 2. In general, most players use it for solo farming, dungeon runs, and casual PvP, while serious players also exploit its full enchant and exceed potential for endgame content. Understanding its stats, soul imprinting, and practical applications can help you make the most of it without relying on hype or speculation. |
