Aion 2 Dragonheart (Skin: Orb) (Bound) Guide – Heroic Skin Reward Voucher Explained - Printable Version
+--- Thread: Aion 2 Dragonheart (Skin: Orb) (Bound) Guide – Heroic Skin Reward Voucher Explained (/showthread.php?tid=92535)
Aion 2 Dragonheart (Skin: Orb) (Bound) Guide – Heroic Skin Reward Voucher Explained - IndigoFable - 12-27-2025
The Dragonheart (Skin: Orb) (Bound) is a cosmetic skin item in Aion 2 that changes the appearance of an Orb-type weapon. It does not affect stats or combat performance. Its main purpose is visual customization.
This skin is classified as a Heroic • Skin Reward Voucher, which means it grants a specific skin when used. Once applied, the skin becomes available in your Closet and can be equipped or removed freely, depending on game rules.
Most players use this skin to personalize their character rather than to gain any gameplay advantage.
What Does “Bound” Mean for This Skin?
Because the item is marked Bound, it usually becomes tied to the character or account once obtained or used. In general, bound skins cannot be traded to other players after binding.
However, according to its properties, the item is marked as Tradable and Storable. In practice, this usually means:
  • It can be stored in account or character storage before use
  • It may be tradable before binding, depending on how you obtained it
  • Once used, the skin itself stays permanently with the character or account
Most players choose carefully which character uses the skin, especially if they play multiple Orb-using classes.
Which Classes Can Use the Dragonheart Orb Skin?
The skin applies only to Orb-type weapons, so only classes that can equip Orbs will benefit from it. The Race and Class fields are open, but in practice, this skin is limited by weapon type, not faction.
Usually, players who main Orb-using classes pick this skin early so they don’t have to change visuals later.
Does the Skin Affect Stats or Item Level?
No. This skin has:
  • Item Level: 0
  • Equip Level: 1
  • Max Enchant: 0
  • Max Exceed: 0
This confirms that it is purely cosmetic.
In general, skins in Aion 2 work independently from your actual weapon stats. You can apply this skin to a low-level Orb or a high-end Orb without changing damage, bonuses, or scaling.
Most players prefer skins like this because they don’t interfere with gear progression.
How Do You Use the Dragonheart (Skin: Orb) (Bound)?
Using the skin is straightforward:
  1. Obtain the Heroic • Skin Reward Voucher
  2. Right-click or activate the item
  3. The skin is added to your Closet
  4. Open the Closet menu
  5. Apply the Dragonheart Orb skin to a compatible weapon
Once unlocked, the skin stays available even if you change weapons later.
Usually, players test the look briefly and then decide whether to keep it active or switch to another skin.
Can the Skin Be Enchanted or Modified?
The item properties list Enchantable, but this refers to the item itself rather than the cosmetic effect.
In practice:
  • You cannot enchant the skin to gain stats
  • Any enchantment applies to the weapon, not the skin
  • The visual appearance remains the same regardless of enchant level
This is standard behavior for most skins in Aion 2.
Can You Decompose the Skin Item?
Yes, the item is marked as Decomposable.
However, most players do not decompose Heroic skins unless:
  • They already unlocked the same skin
  • They are sure they won’t use it
  • They need materials urgently
Once decomposed, you cannot recover the skin unless you obtain it again.
Where Do Players Usually Obtain This Skin?
The Dragonheart (Skin: Orb) (Bound) is typically obtained through:
  • Skin reward vouchers
  • Event rewards
  • Special drops or progression systems
  • Limited-time content
The exact source can vary depending on region and patch version. In general, skins like this are not random loot from regular mobs.
Some players look for external sources of information or trading opportunities, and you may see references like Find and buy Aion 2 items at U4N mentioned in discussions, but how you obtain the skin depends on your server rules and available content.
Is This Skin Worth Using?
Whether the Dragonheart Orb skin is worth using depends on your priorities.
Most players consider:
  • Visual theme and character identity
  • Matching armor or other skins
  • Long-term use of Orb weapons
Because it does not affect gameplay, the value is mostly personal. Players who care about visual consistency often keep this skin equipped for a long time.
Common Questions Players Ask
Can I use this skin on multiple characters?
Usually no. Once bound and used, it stays with one character or account, depending on system rules.
Can I remove the skin later?
Yes. Skins can usually be toggled on or off in the Closet without destroying them.
Does it work with future Orbs?
In general, yes. As long as the weapon type is compatible, the skin can be applied.
Is it rare?
It is considered Heroic-tier, which is not the rarest but not common either.
Final Thoughts from a Player Perspective
The Dragonheart (Skin: Orb) (Bound) is a straightforward cosmetic option. It doesn’t change how you play, but it does change how your character looks.
Most experienced players treat skins like this as long-term visual choices. If you like the design and plan to use Orb weapons regularly, it’s a reasonable skin to unlock and keep.
