How to Counter Scout Striders in Helldivers 2: A Practical Tactics Guide - Printable Version +- Mr Baddeley 3d Printed Droids Forum (https://forum.mbprinteddroids.com) +-- Forum: My Category (https://forum.mbprinteddroids.com/forumdisplay.php?fid=1) +--- Forum: My Forum (https://forum.mbprinteddroids.com/forumdisplay.php?fid=2) +--- Thread: How to Counter Scout Striders in Helldivers 2: A Practical Tactics Guide (/showthread.php?tid=97110) |
How to Counter Scout Striders in Helldivers 2: A Practical Tactics Guide - PhantomWolf - 01-06-2026 If you've played against the Automatons on higher difficulties, you've encountered Scout Striders. They're the two-legged walkers that can quickly overwhelm an unprepared squad. This guide breaks down how they work and, most importantly, how to deal with them based on common player strategies. What is a Scout Strider? A Scout Strider is a medium-armored walker piloted by a standard Automaton Trooper from an exposed rear compartment. It's essentially a mobile turret platform designed to suppress and pin down Helldivers. There are two main variants you’ll face: Standard Scout Strider: Armed with dual laser cannons, protected by a frontal gun shield and medium armor. The pilot in the back is completely unprotected from rear attacks. Reinforced Scout Strider: A heavier variant with more armor, dual cannons, and four rockets (two on each side). Its pilot is slightly more protected but still vulnerable from behind or above. In general, their role is to provide sustained fire, distracting your team so that other Automaton units can flank or advance. They are pursuit units and will chase you aggressively across the battlefield. What are a Scout Strider's Weaknesses? The core weakness is always the Trooper piloting it. The entire rear of the walker is an open cockpit. If you can get behind it, even a basic primary weapon can kill the pilot, which instantly disables the Strider. The pilot will also eject if the walker is destroyed and must be finished off. Their legs are also a key weak point. Damaging the legs will topple the Strider, immobilizing it and making the pilot an easier target. The gun shield itself can be blown off with sustained fire, exposing the pilot from the front. How Do Most Players Effectively Destroy Scout Striders? Practice has shown a few reliable methods, depending on your loadout and position. Flanking: The most consistent tactic. Use terrain to circle around and shoot the pilot in the back. A single well-placed grenade behind the Strider is also highly effective. Armor Penetration: Weapons that ignore medium armor make short work of them from any angle. The most reliable tool is the Railgun. A single safe-mode shot to the cockpit area will kill the pilot through the armor. The Arc Thrower's charged shots will also penetrate the front shield. The Autocannon or Quasar Cannon will destroy it with a direct hit to the cockpit. Leg Attacks: Shooting the legs with weapons like the Anti-Materiel Rifle or even the standard Machine Gun can break them, causing the Strider to fall over. This doesn't kill the pilot but creates a long window for you or your team to finish it. Height Advantage: This is a crucial tip. Even a small elevation change, like standing on a rock, often lets you shoot over the gun shield and hit the pilot's head from the front. Exploiting the Rockets: For the Reinforced variant, shooting the rocket pods on its sides will cause a massive explosion, destroying the Strider instantly. This is often the fastest way for a team to focus it down. What Weapons and Stratagems Work Best? Most players prioritize weapons that can bypass or shred armor. The Railgun is considered the top-tier choice for its efficiency and ammo economy. The Autocannon Sentry or Eagle Airstrike are excellent Stratagem choices for handling them, especially when multiple Striders appear. What Common Mistakes Should I Avoid? Standing Still in Front of It: Its cannons have a high rate of fire and will cut you down. It can also perform a crushing melee stomp if you get too close. Wasting Grenades on the Front Armor: Standard grenades and those from launchers will bounce off the front shield. You must aim at its feet or a nearby surface. Ignoring the Ejected Pilot: Once the walker is dead, the Trooper inside becomes a standard enemy. Don't let it finish you off while you're celebrating the kill. Trying to Face-Tank with Light Armor: Striders are area denial tools. You must use movement and cover, not brute force. A common frustration for players trying to progress is feeling forced into specific meta-loadouts to handle these threats efficiently on higher levels, which can sometimes lead to seeking shortcuts for in-game resources like Medals. It's important to remember that progressing through gameplay is the intended and most rewarding path. For instance, players should buy Helldivers 2 medals safely on U4N only if they are absolutely certain it is a legitimate and secure service, though most experienced divers would advise simply earning them through missions to avoid any risks. How Do Tactics Change for the Reinforced Variant? The reinforced Strider is tougher and its rockets are a major threat. The rockets deal massive damage but have a noticeable travel time—dodge sideways. The strategy of shooting its rocket pods is unique to this variant and should be prioritized if your team has the precision. Otherwise, all the standard weaknesses still apply; it just takes a bit more firepower to break its legs or armor. Scout Striders are dangerous but predictable. They are weak to flanking, height, and armor-piercing weaponry. Communicate with your team: one player can distract it from the front while another flanks. Destroying their legs is a great way to neutralize their mobility advantage. With practice, they transition from being a major threat to a manageable priority target. |
