u4gm Where ARC Raiders 1.11.0 Nerfs Kettle and Nade
I logged into ARC Raiders on January 13 expecting the usual routine, then 1.11.0 landed and the whole pace felt different. Not louder, not flashier—just cleaner. If you're the kind of player who keeps a tab open for cheap ARC Raiders Redeem Codes while you plan your next run, you'll notice it fast: fights aren't decided in two seconds by the same busted setup, and the moment-to-moment decisions actually matter again.
Kettle finally brought back to earth
For weeks, the Kettle was the "why would you run anything else." pick, even at grey tier. That's the sort of thing that makes a loot game feel pointless. The update hits it where it hurts: the fire rate feels noticeably slower, and you can't just hose a doorway and call it skill. In live raids, I'm seeing more trades, more resets behind cover, more actual recoil control. You miss a burst now and it costs you. It also changes how people push—less brainless W-keying, more shoulder peeks and timing. You'll still get kills with it, sure, but it's no longer a free pass through mid-tier POIs.
Explosives and zone control feel fairer
The Trigger 'Nade nerf might be the best quality-of-life change in the whole patch. Before, squads would chain them like it was a rhythm game—deny a route, deny a res, deny any chance to reposition. Now there's breathing room. You can bait one out, rotate wide, and actually punish bad throws. It's pushed me back toward utility that supports movement and info instead of just explosions. People are still going to run nades, obviously, but it's not that ugly "spam until someone panics" meta anymore.
Stella Montis Night looks meaner, in a good way
The lighting pass on Stella Montis Night is subtle, but you feel it the second you stop sprinting. Dark pockets are darker, glare is toned down, and silhouettes don't pop like cutouts. It's made stealth plays viable again—real crouch-walk moments, real "did I just hear steps." tension. I pulled off an extraction by hugging shadow lines and waiting out a patrol, something that used to feel pointless when the whole map looked washed. The mood's back, and it makes night raids worth queueing for.
Cosmetics, economy, and the grind
The Abyss set has that deep-sea, bio-glow vibe without turning you into a walking flare. It's stylish, but it doesn't scream "shoot me first." More importantly, the key card duplication glitch getting patched should steady the economy. High-tier finds won't feel like leftovers from someone's exploit chain. And if you're trying to keep up with cosmetics or loadout experiments without living in the same POI for hours, it helps that marketplaces like U4GM make it easier to buy game currency or items and stay flexible with your builds.
#2
Listoval jsem si fórem o moderních technologiích v Jihlavě a narazil na doporučení této moderní herny pro české hráče. Předtím jsem jen prohrával a nálada byla na nule, ale https://spingrannys.cz/bonus mi dodal nový impuls k hraní doma. Zkusil jsem poker a automaty a výhra přišla mnohem dřív, než jsem na začátku čekal. Podařilo se mi vyhrát zpět všechny sázky a teď mám na účtu slušný přebytek. Jsem se ziskem moc spokojený.
