Herbal Bandage vs Sterilized Bandage: Which One Should You Use in Arc Raiders?
What is the Herbal Bandage?
The Herbal Bandage is a commonly used item that offers a gradual healing effect over time. Unlike immediate-use healing items, the Herbal Bandage restores health slowly, which can be useful during extended battles or while you're trying to stay under the radar after taking some damage.
Key Features of the Herbal Bandage:
  • Healing Rate: 3.5 health per second
  • Duration: 10 seconds of healing over time
  • Use Time: 1.5 seconds to apply
  • Stack Size: 5 in one inventory slot
  • Weight: 0.15 (lightweight)
  • Crafting Materials: Durable Cloth + Great Mullein (Medical Lab 1)
  • Recycled Materials: Fabric + Great Mullein
  • Price: 900 coins when bought from vendors like Lance
This bandage works great for a slow, but steady recovery, especially in situations where you can’t afford to stop moving for long periods.
What is the Sterilized Bandage?
The Sterilized Bandage, on the other hand, is more specialized and efficient when you need a faster recovery from your injuries. This bandage applies a more immediate effect, making it an ideal choice when you're in a fast-paced battle and need to heal quickly.
Key Features of the Sterilized Bandage:
  • Healing Rate: Instantly restores a large portion of health
  • Use Time: A little faster than the Herbal Bandage (instant)
  • Weight: 0.1 (lighter than the Herbal Bandage)
  • Crafting Materials: Typically requires high-tier crafting materials and medical facilities.
  • Price: Generally more expensive than the Herbal Bandage when bought
While the Sterilized Bandage offers faster healing, its key disadvantage is that it doesn’t offer the same duration-based healing as the Herbal Bandage. Once you use it, the healing is done, and you’ll need to wait for your cooldowns to finish or find another bandage to continue healing.
When Should I Use the Herbal Bandage?
The Herbal Bandage is particularly useful in situations where you don’t need an immediate burst of healing, but rather a steady restoration over time. Here are some scenarios when the Herbal Bandage is a good option:
  • Extended Engagements: If you're in a prolonged fight or exploration where you can't afford to stop for a health pack, the Herbal Bandage's gradual healing can help you stay alive as you move.
  • Low on Resources: If you're low on coins or healing items, crafting or buying Herbal Bandages is a reliable, affordable option for keeping your health up.
  • Avoiding Attention: The slow, steady healing effect means that you can heal while staying hidden, which is ideal when you're trying to avoid detection by enemies or other players.
When Should I Use the Sterilized Bandage?
The Sterilized Bandage, thanks to its immediate healing, is better suited for situations where time is of the essence and you need to heal up quickly. It’s especially useful in these cases:
  • Fighting High-Value Targets: When you're in intense combat and need to restore a large portion of health instantly to survive an onslaught.
  • Quick Recovery After Injury: If you’ve taken a lot of damage and need to regain health without waiting for the Herbal Bandage to work over time, the Sterilized Bandage can be a lifesaver.
  • Emergency Situations: In fast-paced environments where enemies are closing in, using the Sterilized Bandage can ensure you're not caught vulnerable with low health.
What Are the Crafting Materials for Each Bandage?
To craft the Herbal Bandage, you need:
  • Durable Cloth
  • Great Mullein
These are relatively easy to gather and craft, making it a great option for those early in the game or players looking to keep their stockpile full without spending too many resources.
For the Sterilized Bandage, the materials are often higher-tier and harder to find, meaning you may need to prioritize its use when you're in need of a more significant healing item. The exact materials can vary based on your crafting setup and progression.
Which Bandage is Better for Fast Recovery?
If you’re asking whether you should buy arc raiders items fast delivery for quicker access to these healing bandages, you should consider your current game needs. The Sterilized Bandage is great for fast recovery in emergencies, while the Herbal Bandage serves well when you need healing over time and don't want to waste valuable resources on immediate-use items.
However, when resources are tight or you’re crafting for a more extended mission, Herbal Bandages are often the more practical option. If you’re a scavenger or low on funds, consider opting for Herbal Bandages to keep your health topped off gradually.
Which Bandage Should I Choose?
Both the Herbal Bandage and Sterilized Bandage serve their purposes in Arc Raiders, but your choice depends on the situation:
  • Herbal Bandage: Ideal for gradual healing, resource conservation, and situations where you don’t need immediate healing.
  • Sterilized Bandage: Best for quick, emergency healing during intense battles where every second counts.
As an experienced player, I’d suggest keeping a balanced mix of both in your inventory. If you’re going on an extended mission or scavenging run, stock up on Herbal Bandages for slow, sustained healing. If you're diving into battle or expecting heavy combat, make sure you have some Sterilized Bandages on hand for quick recovery.
[Moded Weapon] Kettle IV (Ultimate) | All Platform
