U4GM Fallout 76 Why Plastic Farming Matters More Than Youd Think
Need plastic fast in Fallout 76? Farm Morgantown or Watoga High, loot cafeterias and gyms, then top up with Whitespring resort runs, CAMP collectors, and vendor bulk buys.
Plastic never seems to last in Fallout 76. You craft a batch of ammo, throw together a few CAMP bits, maybe make some grenades, and suddenly the stash is empty again. Most players deal with that by farming one place over and over, but that gets old fast. I've had much better results by mixing quick loot runs with passive collection, and if you're the sort who likes shortcuts, sites like U4GM are often mentioned by players looking for game items and extra help without wasting half the night on one resource.
Start with the schools
If you want a fast plastic run, high schools are still hard to beat. Morgantown High School is usually the first place I hit, and Watoga High School works the same way. Don't overthink it. Walk through the gym, cafeteria, classrooms, and side rooms, then pick up anything obviously plastic. Plates, cups, utensils, pumpkins, trays, all of it. It looks like junk when it's sitting there, but once you scrap the lot, the numbers add up way quicker than people expect. You'll also notice these places are easy to learn after one or two runs, so they become proper routine farms instead of messy scavenging sessions.
Check leisure spots and everyday buildings
After that, I usually swing by Whitespring. A lot of players focus on enemies there, but the better move is checking the resort interiors, rec areas, and dining spaces. Pool balls are worth grabbing every single time. Golf clubs too. Then you've got all the random food service clutter sitting around in kitchens and tables. It's not glamorous, but it works. The same idea applies to smaller spots across the map. Diners, motels, roadside cafés, even places you'd normally sprint past can hide a decent pile of plastic if you slow down for a minute. If your carry weight is rough, use Pack Rat or bring some food buffs, because these runs get heavy before you realise it.
Let your CAMP do some of the work
The smart play is making sure plastic keeps coming in even when you're not actively farming it. If your CAMP is on a junk pile, put an extractor down and let it tick away while you're off doing events or dailies. It won't flood your stash overnight, but it helps smooth things out. Collectrons are useful as well, especially if they're bringing back toys, games, and assorted scrap that breaks down into materials you'd actually use. This is the sort of setup that doesn't feel impressive at first, then a week later you realise you've saved yourself several long scavenging runs just by letting the base handle part of the grind.
Buy what you can't be bothered to farm
There's also no shame in spending caps when time matters more than efficiency. Robot vendors around Whitespring Mall can sometimes stock bulk plastic or enough junk to cover what you need right away. I wouldn't rely on vendors alone, but paired with one clean school run and a CAMP setup that keeps feeding you scrap, it's more than enough to stop plastic from becoming a constant headache. And if you're trying to speed up other parts of your build at the same time, plenty of players also browse Fallout 76 iteams while planning out their next crafting session, which honestly makes the whole resource chase feel a lot less annoying.
Users browsing this thread:
