What carries your fuel should be as reliable as the hand that holds it
A hose is not a hero. It does not announce itself. But when a transfer stops halfway because the rubber gave way, or when a slow leak stains the ground, that is when you notice its absence. This is about protecting what matters: your time, your resources, and the ground beneath your feet.
Who We Are
We are a small group of suppliers who decided early that we would not sell what we would not use ourselves. Our warehouse is not a museum of shiny products. It is a working space where hoses are uncoiled, bent, and inspected by people who know the difference between a manufacturing flaw and an acceptable seam. Our values are three: honesty about limits, precision in specifications, and speed when something breaks. We have been doing this for fourteen years. Our expertise is narrow but deep—only industrial hoses, only for petroleum-based fluids.
What We Offer
Hoses for fuel, oil, and petroleum products in three main categories: light-duty transfer, medium-duty dispensing, and heavy-duty suction and discharge. Light-duty hoses are flexible and lightweight for hand-held nozzles. Medium-duty models include static wire for grounding and a nitrile tube that resists swelling. Heavy-duty hoses have dual spiral reinforcement and a cover that tolerates dragging across concrete. All options come in lengths from 5 to 50 metres. Custom lengths are cut to order without extra charge. The unique property is the bonding between layers—no delamination, no internal blistering, even after thousands of pressure cycles.
When It’s Useful
  • Construction sites where generators and excavators need daily refuelling from mobile tanks.
  • Marinas transferring diesel to boat tanks where a spill is both costly and illegal.
  • Workshops changing oil in heavy trucks and tractors.
  • Farms storing biodiesel blends that degrade ordinary rubber within months.
  • Factories moving coolant oils between CNC machines.
  • Tank truck loading and unloading at depots.
  • Emergency generators tested weekly—because a cracked hose discovered on a Friday evening means a weekend of worry.
Why Choose Us
Other suppliers offer hoses with generic “suitable for oil” labels. We provide exact pressure ratings, temperature ranges, and chemical compatibility charts for each product. We also keep spare fittings and clamps in stock—not as an afterthought, but as part of the same order. If a hose arrives and does not fit, we replace it within two business days, no arguing. And we do not hide behind fine print. The hose you see in the photograph is the hose you receive. No digital retouching of threads or thickness.
Call to Action
Look through the collection. Read the technical notes. Choose a hose that will not let you down halfway through the job.
https://novacon.com.ua/shlanhy-dlia-palyva-masla-ta-inshykh-naftoproduktiv/
