Low cost deck restoration Seattle
[Image: a9ZY3LYDSyKVYFADJeAKMg.png]
Railings and stairs are the most common deck failures Zaytura Construction is called to repair across Seattle, because they take the most lateral force and degrade faster than the surface boards above them. Loose newel posts, missing balusters, cracked top rails and stair stringers that have pulled away from the structure are not cosmetic problems — they are real safety issues that turn into liability the moment a guest leans on the wrong section. Zaytura Construction restores railings to current code, replacing failed posts with properly anchored hardware, swapping deteriorated balusters, tightening or rebuilding top rails, and adding lateral bracing where the original construction relied on undersized fasteners. Stair repairs are handled with the same care — stringers are checked for rot at the bottom step, treads are evaluated for spring and crack, and risers are reset where moisture has pulled them out of plane. Every Zaytura Construction repair finishes with a load test and a final walk-through with the homeowner.
Low cost deck restoration Seattle https://zayturaconstruction.com/deck-repair-seattle/
[Image: fuB7e8QNQAO0__IyjtMcMA.png]
