What to Do During Water Restrictions – LawnBySeason
Water Restrictions are a common reality for homeowners, especially during periods of drought or high water demand. If you’re maintaining your yard through LawnBySeason, understanding how to adapt is key to keeping your lawn healthy without violating local rules.
Water Restrictions typically limit when and how often you can use sprinkler systems. While this may sound alarming, most lawns are more resilient than they appear. Warm-season grasses can tolerate several weeks without irrigation by entering dormancy, turning brown while preserving their root systems. With proper care, they recover quickly once watering resumes.
The best approach during Water Restrictions is to focus on efficiency rather than frequency. Water deeply on permitted days to encourage deeper root growth. Shallow watering leads to weaker grass that struggles in dry conditions. Adjusting your mowing height is also essential—keeping grass slightly taller helps shade the soil and retain moisture.
[Image: water9.jpg]
Avoid fertilizing during restricted periods. Fertilizers stimulate new growth that requires more water, putting unnecessary stress on your lawn. Instead, allow your grass to rest naturally.
LawnBySeason recommends prioritizing high-value plants like trees and shrubs, which benefit most from limited water. Lawns, on the other hand, are built to recover.
With the right strategy, Water Restrictions don’t mean losing your lawn—they simply require smarter, more mindful care.
