How to Migrate Google Drive to OneDrive Without Losing Your Data
Switching from Google Drive to OneDrive is something many businesses and individuals are doing as they shift toward the Microsoft 365 ecosystem. The process is straightforward if you plan it properly and use the right tools.
Take Stock of Your Google Drive Data
Start by reviewing everything sitting in your Google Drive. This includes personal files, shared folders, team drives, and any Google Docs, Sheets, or Slides files. Native Google formats will need to be converted to their Microsoft equivalents during migration, so knowing the volume upfront helps you plan better.
Set Up OneDrive Before You Begin
Make sure your OneDrive environment is ready before kicking off the migration. Assign storage space, set up user accounts, and check that permissions are configured the way you want them on the Microsoft side. Rushing this step often causes folder structure problems later.
Use a Reliable Migration Tool
Doing this manually through download and upload is tedious and prone to errors, especially with large amounts of data. Shoviv Google Drive to OneDrive Migration Software takes the heavy lifting out of the process. It migrates files, folders, and shared drives directly from Google Drive to OneDrive while keeping the original folder hierarchy intact. The software also supports delta migration, meaning only new or changed files are transferred in subsequent runs, which saves time significantly. It handles bulk user migration as well, which is a big plus for businesses moving entire teams.
Do a Test Run First
Before running the full migration, test it with a small batch of data. This helps you spot any issues with file naming, permissions, or folder mapping before they become a wider problem.
Verify and Finalize
Once migration is complete, have users log into OneDrive and check their files. Look for missing folders, broken links, or any files that did not convert properly.
With good preparation and the right software, moving from Google Drive to OneDrive is a manageable task that does not have to disrupt your workflow.
