1 hour ago
Crustle ex-B3 is a tough rogue pick in Pokemon TCG Pocket, using bulk, Lucario boosts, and smart healing to punish ex decks, though its high retreat cost keeps it out of top tier.
Crustle ex-B3 has turned into one of those cards that splits opinion fast in Pokemon TCG Pocket. Some players wrote it off straight away because of the clunky retreat cost and the slower setup. Others stuck with it and found a tank that can drag games into uncomfortable places for the opponent. If you spend any time around deck discussions, or even browse trading and account resources like U4GM while tracking the meta, you'll notice Crustle ex keeps coming up for one simple reason: it's not top tier, but it's a lot better than people first thought. In the right room, against the right field, it can absolutely punish careless players.
Why the deck can steal games
The big selling point is obvious once you play a few matches. Crustle ex takes hits and sticks around. That alone matters in a meta where a lot of decks want to race, pile on pressure, and force quick prizes. When you add Lucario support, the deck stops feeling passive. Suddenly Crustle isn't just soaking damage, it's pushing back with real numbers. That's where people get caught out. They expect a wall, then realise they're losing tempo because the wall is actually swinging hard enough to matter. Defensive tools like Heavy Helmet and healing cards make the whole plan even more annoying, especially for ex-heavy lists that don't like long trades.
Where things start to fall apart
Still, the weaknesses are hard to ignore. The retreat cost is brutal, and there's no clean way to sugar-coat that. If Crustle gets dragged into awkward spots, or if your bench has to be protected in a hurry, you can feel trapped. That's usually when the match starts slipping. Fast decks don't give you much room either. Zoroark ex and Mega Lucario ex can get rolling before Crustle really settles in, and once you're behind, this deck doesn't always have the speed to fix it. There's also the matchup issue. Against spread damage, disruption, or lists built around efficient non-ex attackers, Crustle can look pretty ordinary. Fire decks are another headache, and not a small one.
How good players actually pilot it
If you want results with Crustle ex-B3, you can't just throw it into the Active Spot and hope the HP total does the work. Good players are careful from turn one. They don't overfill the bench. They don't burn healing too early. They try to get Lucario online quickly, then manage the board so Crustle never has to retreat unless there's no other option. That's the real skill test with this deck. It's less about flashy turns and more about pacing. You're asking the opponent to overextend, and a lot of people do. But if they know the matchup and stay patient, the cracks in the strategy show up pretty quickly.
Where it fits in the current meta
Crustle ex-B3 isn't the kind of deck you'd call a safe pick for every event, but that doesn't make it a gimmick. It has a real job in the format as a rogue choice that can punish straightforward ex decks and force slower, uglier games. For players who like control over tempo and don't mind a more deliberate style, there's something here worth exploring. It won't carry itself, and it definitely won't fix poor matchup reads, but in the hands of someone who knows when to commit and when to hold back, it can still put up results. That's a big reason interest in builds, testing, and even Pokemon TCG Pocket Accounts keeps growing among players looking for something different from the usual meta staples.
