05-27-2026, 11:25 AM
Pls try email to franc2051#hotmail.com change # into @ , Ctrl+F to search softwares
3DQuickPress v6.3.3
Advance Concrete 2017
Advance Steel 2026
Advance Steel Extension for Revit 2019-2027
Advanced Design System 2024
AFT Arrow v9.0.1109
Alias Automotive 2015 SP2
Alias AutoStudio 2025.1
Alias Concept 2016
Alias Design 2015 R2
Alias Surface 2015 SP2
Allplan 2023.1
Altair EDEM 2022.2
Altair FlowSimulator 2022.1.1
Altair HyperWorks 2022.1
Altair Inspire 2022.1.1
Altair Inspire Cast 2022.1.1
Altair Inspire Extrude 2022.1.1
Altair Inspire Form 2022.1.1
Altair Inspire Mold 2022.1.1
Altair Inspire PolyFoam 2022.1.1
Altair Inspire Render 2022.1.1
Altair Inspire Studio 2022.1.1
Altair PollEx 2022.1
Altium Designer v23.1.1 Build 15
Antenna Magus Professional 2022.5
Anylogic Professional 8.9.0
ArcGIS Desktop v10.8.2
ArcGis Engine 10.8.2
ArcGIS Engine DevKit 10.2-10.8
ArcGIS Pro v3.6.3
ArchiCAD 27.3.5 Build 6080
ArchiCAD 29 Build 3000
Architecture 2010
Arnold 2027 For Cinema 4D 2024-2026
ArtCAM 2018.2.1
AutoCAD Architecture 2027
AutoCAD Civil 3D 2016 SP4
AutoCAD Design Suite Standard 2021
AutoCAD ecscad 2013
AutoCAD Electrical 2027
AutoCAD LT 2027
AutoCAD Map 3D 2026.0.3
AutoCAD Mechanical 2026
AutoCAD MEP 2026.0.1
AutoCAD Plant 3D 2026.1
AutoCAD Raster Design 2027
Autodesk 3ds Max 2027.1
Autodesk Advance Steel 2027
Autodesk Alias AutoStudio 2024.1
Autodesk Alias Concept 2024
Autodesk Alias Design 2013
Autodesk Alias Surface 2013 SP1
Autodesk AutoCAD 2027
Autodesk AutoCAD Electrical 2023.0.1
Autodesk AutoCAD Mechanical 2027
Autodesk AutoCAD MEP 2025.0.2
Autodesk AutoCAD P&ID 2013 SP2
Autodesk AutoCAD Plant 3D 2024.1.2
Autodesk CAMplete TurnMill 2026
Autodesk CFD Ultimate 2027
Autodesk Civil 3D 2027
Autodesk Data Exchange Connector for Navisworks Manage
Autodesk Data Exchange Connector for Revit 2024-2026
Autodesk Data Exchange Connector for Tekla
Autodesk Fabrication CADmep 2024.0.6
Autodesk Fabrication CAMduct 2026.1
Autodesk Fabrication ESTmep 2025
Autodesk FeatureCAM Ultimate 2026.0.1
Autodesk Geotechnical Modeler Extension 2023-2026 for Civil 3D
Autodesk HSMWorks Ultimate 2026
Autodesk InfoDrainage 2026.3
Autodesk InfoDrainage Ultimate 2027
Autodesk InfoWater Pro 2027
Autodesk InfoWorks ICM Ultimate 2027
Autodesk InfoWorks WS Pro 2027
Autodesk Infrastructure Parts Editor 2021-2026
Autodesk Infraworks 2027
Autodesk Inventor CAM Ultimate 2026
Autodesk Inventor Nastran 2026.3
Autodesk Inventor Professional 2027
Autodesk Inventor Tolerance Analysis 2026
Autodesk Inventor View 2018
Autodesk Manufacturing Data Exchange Utility 2018-2026
Autodesk Maya 2026.3.2
Autodesk Moldflow Adviser 2027
Autodesk Moldflow Synergy 2027
Autodesk MotionBuilder 2015
Autodesk Mudbox 2015 SP1
Autodesk Navisworks Freedom 2016-2025
Autodesk Navisworks Manage 2022.6
Autodesk Navisworks NWC Export Utility 2016-2025
Autodesk Navisworks Simulate 2021.5
Autodesk Netfabb Ultimate 2025 R1
Autodesk Plant 3D 2027
Autodesk PowerInspect Ultimate 2024
Autodesk Powermill 2026.0.1
Autodesk PowerMill Ultimate 2026
Autodesk PowerShape 2024.0.1
Autodesk PowerShape Ultimate 2025
Autodesk Recap Pro 2024.1.3
Autodesk Revit 2027.0.2
Autodesk Revit Extension for MEP Fabrication 2022-2027
Autodesk Revit InfraWorks Updater 2019-2026
Autodesk Vault Basic Server 2026.1.1
Autodesk Vault File Server 2026.1.1
Autodesk Vault Office 2026
Autodesk Vault Professional Client 2026.2
Autodesk Vault Professional Server 2026.2
Autodesk Vred Professional 2024.2.1
AutoPLANT Modeler For AutoCAD v10.01
AVEVA INPLANT Fluid Flow Design 2022
AVEVA PRO/II Simulation 2023.0
AVEVA Process Simulation 2022
Bentley ADINA 2026 v26.00.00.383
Bentley Adina CONNECT Edition v09.09.00
Bentley AutoPIPE 2025 v25.00.01.213
Bentley AutoPIPE Vessel 2026 v47.00.01.27
Bentley CivilStorm 2024 v24.00.00.25
Bentley Descartes 2025 v25.00.00.055
Bentley Descartes CONNECT Edition v10.17.02
Bentley DYNAMEQ v23.00.01
Bentley EasyPower 2025 v25.00.00.8049
Bentley GeoStudio 2025.2.1
Bentley HAMMER 2024 v24.00.00.26
Bentley iTwin Analytical Synchronizer 2023 v23.01.07.033
Bentley iTwin Capture Console 2023 v23.00.02.525
Bentley iTwin Capture Desktop Viewer 2023 v23.0
Bentley iTwin Capture Import and Upload 2024 v24.00.03.02
Bentley iTwin Capture Manage and Extract 2024 v24.00.03.02
Bentley iTwin Capture Modeler 2023 v23.0.3.10
Bentley LEGION 2023 v23.00.00
Bentley LumenRT 2024 v24.00.01.63
Bentley Maxsurf CONNECT Edition v23.07
Bentley MicroStation 2026
Bentley MicroStation CONNECT Edition v23.00.01.44 English
Bentley MOSES 2025 v25.00.01.173
Bentley Multiframe CONNECT Edition v23.06
Bentley OpenAirport Designer v24.00.00.195
Bentley OpenBridge Designer 2025 v25.00.01.16
Bentley OpenBridge Designer CONNECT Edition v23.00.00
Bentley OpenBridge Modeler 2025 v25.00.01.25
Bentley OpenBuildings Designer 2024 v24.00.02.45
Bentley OpenBuildings Designer CONNECT Edition v23.00.00.114
Bentley OpenBuildings Speedikon CONNECT Edition v10.04.01 English
Bentley OpenCities Map Ultimate 2025
Bentley OpenFlows CivilStorm CONNECT Edition v10.04.00.158
Bentley OpenFlows HAMMER v24.00.00.24
Bentley OpenFlows Sewer 2026 v26.00.00.513
Bentley OpenFlows SewerCAD CONNECT Edition v10.04.00.158
Bentley OpenFlows SewerGEMS CONNECT Edition v10.04
Bentley OpenFlows Storm 2026 v26.00.00.513
Bentley OpenFlows StormCAD CONNECT Edition v10.04
Bentley OpenFlows Water 2026 v26.00.00.513
Bentley OpenFlows WaterCAD 2024 French v24.00.00.26
Bentley OpenFlows WaterGEMS v23.00.00.19
Bentley OpenPlant Isometrics Manager v24.00.03.09
Bentley OpenPlant Modeler 2024 v24.00.03.015 English
Bentley OpenPlant Modeler CONNECT Edition v10.11 English
Bentley OpenPlant Modeler v24.00.03.53
Bentley OpenPlant Orthographics Manager 2024 v24.00.03.16
Bentley OpenPlant PID 2024 v24.00.03.22 English
Bentley OpenPlant PID CONNECT Edition v10.11.01
Bentley OpenPlant Project Administrator 2024 v24.00.03.010 English
Bentley OpenPlant Support Engineering 2024 v24.00.03.007
Bentley OpenRail Designer CONNECT Edition V10.12
Bentley OpenRail Overhead Line Designer 2023 v23.00.00.129
Bentley OpenRoads Designer 2024 v24.00.02.025
Bentley OpenRoads SignCAD 2024 v24.00.00.56
Bentley OpenSite Designer 2024 v24.00.02.025
Bentley OpenSite Designer CONNECT Edition V10.12
Bentley OpenTower Designer 2025 v25.00.00.01
Bentley OpenTunnel Designer 2025 v25.00.00.226
Bentley OpenUtilities Substation CONNECT Edition v10.12
Bentley OpenWindPower Floating Platform 2024 v24.00.02.182
Bentley PLAXIS 2D 2025.1.3
Bentley Plaxis 3D 2025.1.3
Bentley PLAXIS Monopile Designer v24.01.00
Bentley Pointools CONNECT Edition v10.02.00
Bentley ProStructures 2024 v24.00.03.34 German
Bentley ProStructures CONNECT Edition v23.00.00.055
Bentley ProStructures For AutoCad v10.02.00.04
Bentley Raceway and Cable Management 2024 v24.00.03.10
Bentley RAM Concept 2025 v25.0.0
Bentley RAM Connection 2025 v25.0.2
Bentley RAM Elements 2024 v24.0.4
Bentley RAM Structural System 2025 v25.0.2
Bentley RCDC CONNECT Edition v23.00.00
Bentley SACS Offshore Structure 2024 v24.00.01.05
Bentley SewerGEMS 2024 v24.00.00.25
Bentley STAAD Pro 2025 v25.00.01.424
Bentley STAAD Pro CONNECT Edition v23.00.03.025
Bentley SYNCHRO 4D Pro 2025 v06.05.06.30
Bentley SYNCHRO OpenViewer 2026 v06.05.08.13
Bentley Synchro Pro v6.5.5.28 For Navisworks 2025
Bentley SYNCHRO Scheduler 2026 v06.05.08.13
Bentley View 26.00.00.57
Bentley WaterCAD 2024 v24.00.00.26
Bentley WaterGEMS 2024 v24.00.00.26
Bentley WaterGEMS CONNECT Edition v23.00.00.19
BETA CAE Systems v20.1.6
BIM Interoperability Tools for Revit 2019-2026
BricsCAD v24.1.07
Building Design Suite 2012
Building Design Suite Ultimate 2020
Cadence Allegro and OrCAD 2022 v22.10.001
CAMWorks 2022 SP5 For SolidWorks 2021-2023
CFD Ultimate 2019.2
Chaos Corona 13 Hotfix 2 For 3ds Max 2022
ChemOffice Suite 2021 v21.0.0.28
Cinema 4D R23.110 For Win/Mac
Civil 3D 2026.2.1
CMG Suite 2021
ColorGATE v23.01
COMSOL Multiphysics v6.1
ContextCapture CONNECT Edition v10.20
Corel Painter 2023 v23.0.0
Corel PaintShop Pro 2023 Ultimate v25.1.0
Corel VideoStudio Ultimate 2023 v26.0.0
CorelDraw Graphics Suite 2026 v27.0.0.121
Cradle CFD 2022.1
Creo 4.0 With M150
Creo v7.0.12.0
CSI CSiBridge v26.3.0
CSI CSiDetail v18.1.1
CSI CSiXCAD v19.30
CSI ETABS v23.2.0
CSI Perform3D v8.0.0
CSI SAFE v22.7.0
CSI SAP2000 v27.1.0
DB Link for Revit 2022-2027
Dlubal RFEM v5.29.01
Dlubal RSTAB v8.30.01
DS SIMULIA Suite 2023 (Abaqus/Isight/Fe-safe/Tosca)
DS Simulia XFlow 2022.116
DWG TrueView 2018-2024
Dynamo Extension for Advance Steel 2019-2027
Dynamo Extension for Robot Structural Analysis 2021-2027
ECS FEMFAT v5.4
EFICAD SWOOD 2021 SP4.2 For Solidworks 2022
Enscape v3.5.4.119962
EPLAN Electrical P8 2023
ESI PAM-STAMP 2022.0
ESI ProCAST 2022.0
ESI Visual-Environment 18.0
ESSS Rocky DEM 2022 v22.2.0
ETA Inventium PreSys 2019 R1
Fabrication CADmep 2014 SP4
Fabrication CAMduct 2014
Factory Design Utilities 2026.1.2
FeatureCAM Ultimate 2027
FLEXnet Feature Codes For Autodesk Products 2024
FTI Forming Suite 2022.0.2 Build 34003.0
Geomagic Control X v2024.1.0.65
Geomagic Design X v2024.1
Geomagic Foundation 2014 SR3
Geomagic Freeform Plus v2024.0.87
Geomagic Sculpt 2019
Geomagic Studio 12.0
GEO-SLOPE GeoStudio 2018 R2
GeoStudio 2025.1 v25.01.00.1058
GIBBSCAM 2026 v26.0.46
Grading Optimization for Civil 3D 2022-2026
GraphiSOFT ArchiCAD 28 Build 3001
3DQuickPress v6.3.3
Advance Steel 2026
AFT Arrow v9.0.1109
Alias Concept 2016
Allplan 2023.1
Altair EDEM 2022.2
ArcGIS Pro v3.6.3
Architecture 2010
ArtCAM 2018.2.1
AutoCAD ecscad 2013
AutoCAD LT 2027
BricsCAD v24.1.07
CFD Ultimate 2019.2
Civil 3D 2026.2.1
CMG Suite 2021
ColorGATE v23.01
Cradle CFD 2022.1
Creo 4.0 With M150
Creo v7.0.12.0
CSI CSiXCAD v19.30
CSI ETABS v23.2.0
CSI SAFE v22.7.0
CSI SAP2000 v27.1.0
ECS FEMFAT v5.4
ESI ProCAST 2022.0
