Which Wheels Work Best in Forza Horizon 6
The best racing wheels for Forza Horizon 6 vary depending on how much you want to spend and how serious you are about sim driving. One thing is clear though: the game’s improved wheel physics and handling model make a noticeable difference compared to older entries. Steering input feels more precise, and force feedback is stronger and more responsive, especially on technical roads and high-speed sections of the Japan-inspired map.
Because of this upgrade, using a proper wheel setup instead of a controller can completely change the driving experience. Below is a breakdown of the best options across different budgets, plus some important setup tips to get the most out of your gear.
Best Entry-Level Wheels (Under $300)
Entry-level wheels are still the most common starting point. They are easy to set up, widely supported, and work well straight out of the box.
Logitech G920 / G29 / G923
These remain some of the most reliable wheels for beginners.
Pros:
Very stable and widely supported
Plug-and-play compatibility with Forza Horizon 6
Consistent performance for casual and semi-serious driving
Cons:
Gear-driven system can feel noisy
Less smooth force feedback compared to newer designs
Even with their older design, Forza Horizon 6’s improved controller dampening helps these wheels feel more stable and less “loose” than in previous titles.
Thrustmaster T128 / T248
These models use a hybrid-style force feedback system that blends different feedback methods.
Pros:
Better surface feedback for asphalt, dirt, and snow
T248 includes a built-in telemetry display
More modern feel than older gear-driven wheels
Cons:
Mostly plastic construction
Not as refined as direct drive systems
Best Mid-Range and Direct Drive Wheels ($300–$600)
This is where the biggest performance jump happens. Direct Drive (DD) wheels connect the steering wheel directly to the motor, which results in much more accurate force feedback and faster response times. In a game like Forza Horizon 6, this makes a big difference when catching slides or driving on narrow mountain roads.
MOZA Racing R3 Bundle
Pros:
One of the best entry points into direct drive on Xbox and PC
Strong precision for drifting and mountain driving
Very responsive steering feedback compared to gear-based wheels
This is often considered the “sweet spot” for players who want a serious upgrade without going into high-end pricing.
MOZA R5 Bundle
MOZA R5 Bundle
Pros:
Around 5.5 Nm of torque (PC version)
Much stronger and more realistic force feedback
Great for players who want more resistance and road feel
The R5 is especially good for players who want a more realistic driving load and better long-session control.
Fanatec CSL DD QR2 Wheelbase
Pros:
Very smooth and refined force feedback delivery
Large ecosystem of interchangeable wheel rims
Strong reputation in the sim racing community
This setup is ideal for players who want to build a long-term sim racing rig with upgrade flexibility.
Best Premium and High-End Wheels ($700+)
High-end wheelbases are designed for players who want maximum realism and long-term competitive performance.
Logitech G Pro Racing Wheel
Pros:
Excellent plug-and-play performance in Forza Horizon 6
High compatibility with custom rigs and accessories
Very strong and consistent force feedback
This wheel is designed to work smoothly across both casual and competitive driving setups.
ClubSport DD
ClubSport DD
Pros:
Extremely strong and stable force feedback
No noticeable performance drop during long sessions
Built for serious sim racing environments
This is aimed at players who spend a lot of time in competitive racing or high-intensity driving sessions.
Critical Settings Tips for Forza Horizon 6
To get the best performance out of any wheel, in-game and hardware settings matter just as much as the device itself.
1. Steering Rotation
720° for standard grip racing
540° for drift-focused setups or faster steering response
2. Wheel Damper Settings
Higher (around 1.8) for gear-driven wheels like Logitech G series to reduce sudden snapping
Lower (around 1.2) for direct drive wheels to keep steering natural and responsive
3. Firmware Updates
Always update your wheel’s firmware and drivers before launching the game. This helps prevent force feedback issues and ensures full compatibility with Forza Horizon 6.
Forza Horizon 6 rewards precise steering and fast feedback more than previous entries in the series. While entry-level wheels like Logitech and Thrustmaster models are still solid choices, the biggest improvement comes from moving into direct drive systems like MOZA or Fanatec.
If you are just starting out, entry-level wheels will still deliver a good experience. But if you want full control on mountain roads, drifting sections, and high-speed racing, upgrading to a direct drive setup is where the game really opens up.
