The Ultimate Tesla Cannon Guide for Fallout 76
Tesla Cannon is an amazing new weapon added to Fallout 76. This weapon has stirred up excitement in the community, and after extensive testing, I’m here to give you the lowdown on its potential and why it’s worth using.
How to Get the Tesla Cannon in Fallout 76
The Tesla Cannon is available through the Season Pass at the moment. If you're watching this later, it’s likely that the weapon will be available through Gold Bullion Vendors or Stamp Vendors, just like other weapons added in the past. If you're looking to add it to your arsenal, keep an eye on these vendors after the Season Pass is over!
Weapon Overview: Is the Tesla Cannon Good?
While the Tesla Cannon isn't a game-changer in terms of raw DPS compared to weapons like the BOS (Brotherhood of Steel) weapons, it has some unique features that set it apart. These are the "secrets" that aren’t obvious from the description alone. In this review, I’ll walk you through the weapon’s modifications, legendary effects, and how to get the best use out of it.
Best Modifications for the Tesla Cannon
There are two main configurations for the Tesla Cannon, and both have their unique advantages.
    Explosive Bloodied Tesla Cannon
        Legendary Effects: Bloodied, Explosive, Durability Polished (A word of caution – don’t install durability too early!)
        Pros: High explosive damage, wall-piercing explosions, excellent against large groups of enemies.
        Downsides: Must be used with a Bloodied build to maximize damage potential. If you’re a full-health build, anti-armor won’t be effective. The explosive setup is best suited for Bloodied builds.
    Anti-Armor Tesla Cannon
        Legendary Effects: Anti-Armor, Weapon Speed (to enhance damage output)
        Pros: Works well for high DPS, especially with Pinpoint pointers for added damage.
        Downsides: Lower direct impact damage compared to the explosive variant but shines with chain lightning effects.
Key Features and Secrets of the Tesla Cannon
    Wall-Piercing Explosions
    The most exciting feature of the Explosive Tesla Cannon is its ability to fire wall-piercing explosions. This is a unique ability that no other weapon in Fallout 76 has, allowing you to deal damage through walls and hit enemies that would otherwise be out of sight. It’s a game-changer when dealing with multiple enemies behind cover.
    Durability and Polished Effect
    When modding for Polished Durability, make sure your durability bar isn’t at 200% before you install the upgrade. If it is, the durability bonus won’t apply. It’s best to keep the durability bar slightly below 200% to reap the maximum benefits.
    Weapon Speed and Fire Rate
    While it might be tempting to mod the Tesla Cannon for higher fire rate, it’s not recommended. Higher fire rates result in more ammo usage without significant damage improvement. For a Tesla mod, a lower fire rate ensures better ammo efficiency.
    Effective in Both PvE and PvP
    The Tesla Cannon is incredibly effective in PvE scenarios, especially for tagging enemies at long range or behind cover. However, the explosive variant is not ideal for VATS due to the self-damage risk. For VATS combat, the Tesla configuration (with chain lightning effects) is much safer and equally effective in damage output.
Combat Tips and Strategy
    Explosive Tesla Cannon: Ideal for hitting multiple enemies at once, even those hiding behind walls. The explosion damage is high, but the risk of self-damage is something to watch out for. If you're using the explosive variant, ensure you're equipped with Assassin's Armor or Power Armor to reduce self-inflicted damage.
    Tesla Configuration: If you’re looking for a safer approach, go with the Tesla mod. It doesn't blind you with its effects, and you’ll benefit from chain lightning, making it excellent for dealing with groups of enemies.
Other Considerations
    Ammo Efficiency: The Explosive Tesla Cannon is high in damage but eats through ammo fast. If you mod it for lower fire rate, you’ll conserve ammo and still get respectable DPS.
    Grenades Combo: When combined with grenades, the Tesla Cannon can deliver devastating damage. Using Nuka Grenades or other high-damage explosives with the Tesla Cannon creates a powerhouse setup.
Is the Tesla Cannon Worth It?
Absolutely! The Tesla Cannon brings a unique set of abilities to Fallout 76, including wall-piercing explosions and chain lightning. While it may not replace the BOS weapons for sheer damage, it’s a fun, versatile weapon with a lot of hidden potential. Whether you're using it in PvE or PvP, it’s a valuable addition to your weapon collection.
For more info, please browse U4GM! This is also the best store  to buy cheap Fallout 76 Caps, Fast Delivery and Best Price!
#2
¿Qué pasa, chavalería? Vi un cartel en Elche y me entró el gusanillo de ver qué tal funcionaba este portal. Había acumulado unas pérdidas que me tenían de mal humor y ya no esperaba recuperar nada de nada. Al final, en play jonny la fortuna me sonrió por fin. Gané una cantidad considerable en las máquinas que tapó todos los agujeros de mis partidas previas. Estoy muy satisfecho y con ganas de celebrar este beneficio.
#3
Desde casa quería entretenerme un poco y explorar sitios de apuestas online confiables. Necesitaba algo fácil de usar y con varias opciones. lucky capone ofrecía todo eso: juegos variados, apuestas deportivas y promociones interesantes. Además, tienen guías y consejos adaptados al público español. Me animó la tarde y me dio tema de conversación con amigos mientras jugábamos juntos.
