04-23-2025, 12:14 PM
If your Lorex camera setup isn’t working properly, start by checking all cable connections and ensuring your devices are powered on. Make sure your internet connection is stable and compatible with the system. Use the Lorex Setup Wizard to guide you through the initial configuration—this tool simplifies network detection, camera pairing, and recording setup. Also, confirm your camera firmware is up to date and that the mobile app is properly synced. If you're using Wi-Fi, check for interference or weak signals. Restart your system and router if needed. Following these steps can often resolve common Lorex camera setup issues efficiently.
