ELD.gg-The Ultimate Melee Build for Path of Exile 2
Today, we're diving deep into the updated Thor build for Path of Exile 2, taking the classic "Moler Thor" fantasy and juicing it with insane single-target damage, chunky AOE, and-most importantly-a solid defensive setup. No totems, no squishy glass cannon setup, and no need to wear Astrometis just to chase attribute requirements. This build is lean, mean, and shockingly effective.
Let's break down what makes this version of the Thor melee build so potent POE 2 Currency Orbs, how it maps, smashes bosses, and maintains a defensively viable playstyle, all while keeping the aesthetics and theme in full swing.
Why Update the Thor Build?
The original Thor build already had a strong thematic identity-massive slams, lightning everywhere, and of course, Hammer of the Gods as your signature nuke. But like many melee archetypes, it suffered from clunky single-target setups (mostly due to totems) and squishiness under heavy boss mechanics. This version solves both.
No more totems. We've gone full melee with Rolling Slam, Infernal Cry, and Hammer of the Gods for brutal, fast-paced gameplay. We also redesigned the passive tree and itemization to squeeze out more survivability and smoothness.
Mapping Setup: Ice Stacked Energy Shield and Moyer Invictus Synergy
For mapping, this build utilizes Energy Shield stacking, paired with the Moyer Invictus chest. It gives access to fast regen and shields while still synergizing with our melee approach. Intelligence-stacked boots help smooth over attribute requirements, and there's no need for Astrometis thanks to the dropped Verdict helmet-you only need 744 Strength, which is manageable even without extreme attribute gear.
Key gear for mapping:
Moyer Invictus Chest (energy shield gain)
Intelligence-focused boots
Vertex or other low-life helm options for flexibility
Single-Target Slayer: Rolling Slam and Hammer of the Gods
Let's talk bossing. This build gets ridiculous single-target DPS using a combo of Rolling Slam, Infernal Cry, Voltaic Mark, and of course Hammer of the Gods. All skills are supported by heavy multipliers like Fist of War and Rageforged. The big trick? We weapon-swap to a damage setup and drop support gems that aren't needed for the boss.
Rotation:
1.Voltaic Mark-breaks armor using Single Out support
2.Infernal Cry-buffs your hits and weakens enemies
3.Rolling Slam-the core DPS skill that stuns and chains aftershocks
4.Seismic Cry-copies slams for even more hits
5.Hammer of the Gods-instant-cast finisher with shock scaling
6.The build runs a 2-second total attack time on Rolling Slam, ensuring 100% aftershock chance, which means each slam hits four times. Seismic Cry brings it to six hits per slam.
Defensive Layers
Every other Thor-style build out there seems squishy. Not this one. This version packs multiple defensive layers:
Energy Shield & Life Hybrid Pool-Up to ~4.4k effective HP
Time of Need-dispels all elemental ailments (shock, chill, ignite, freeze)
Ground Charm or Overcharge Shock Immunity-optional, depending on setup
Low Life Setup-allows better aura stacking and elemental penetration
Hulking Form Ascendancy-grants reduced skill duration and attribute scaling
This means you're shrugging off shocks, freezing winds, ignites, and other ailments automatically every 1.4 seconds. It also gives you more consistency during boss fights, especially when rage is active.
Gems and Supports
This is a build that thrives on gem synergy. From bossing to mapping, the setup is modular depending on your weapon swap.
Core Links for Bossing (Weapon Set 1):
Rolling Slam + Aftershock + Reverberate + Close Combat + Consecrated Effect + Heavy Swing
Hammer of the Gods + Fist of War + Rageforged + Lightning Infusion + Deadly Support
Mapping Gems (Weapon Set 2):
Earthquake + Fire Infusion + Magnified Effect + Splinter (for AOE armor break)
Herald of Thunder + Elemental Focus + Primal Armament + Lightning Penetration
Utility:
Voltaic Mark + Single Out + Overcharge
Raging Cry or Seismic Cry (flex slot)
Berserk for burst damage and rage dump
Inspiration, Tireless, Premeditation to manage cost and amplify cries
Using reduced skill duration clusters makes Hammer of the Gods nearly instant. It feels snappy and consistent in real fights-no awkward "fall-from-the-sky" delay.
Weapon Swap System
The dual weapon setup optimizes performance:
Weapon Set 1 (Red): Heavy single-target focus, slower but stronger
Weapon Set 2 (Green): Faster AoE setup for mapping
This flexibility ensures the build performs in every situation without needing to respec or swap gear extensively.Budget Considerations
Here's the kicker-you don't have to break the bank.
Level 18 Molir is much cheaper (~5-10 divines) than Level 19 (~50+ divines)
Low-life gear ismore accessible with proper attribute scaling
Drop expensive legacy gear like Astrometis in favor of more synergistic rares
The tradeoff is smart spending-high impact where it counts, affordable alternatives where possible.
Min-Maxing and Passive Tree Tips
You're looking to stack strength, but also intelligence where it benefits energy shield. Prioritize these:
Hulking Form: Absolutely mandatory for Strength scaling and reduced skill duration
Polymathy: Scales well with attribute stacking, adds a ton of hidden damage
Unbending + Acceleration Jewel: Provides extra movement and skill speed
Against the Darkness cluster: Excellent for further Strength gain
You'll want to path through strong attribute nodes and pick up rage generation options early. It's worth noting that the build is still missing around 180% increased damage due to unallocated passives-so there's a lot of headroom for growth.
Final Thoughts and Leveling Plans
This updated Thor build doesn't just slap harder-it feels better Path of Exile 2 Currency. Instant slams, shock synergy, massive aftershock explosions, and defensive layers that don't rely on janky mechanics or RNG flukes.
So if you're tired of clunky totem-based melee, if you want something that clears the screen and melts bosses with righteous fury, and if you want to look cool doing it-this Thor 2.0 build might just be your next main in Path of Exile 2.
