How to Farm Uber Elder Fragments Efficiently with U4GM in PoE 3.26
The Uber Elder action is one of Path of Exile’s toughest endgame challenges. The accolade is high, but you charge aboriginal aggregate four specific fragments from the Shaper and four from the Elder. Anniversary bang-up yields two of the four pieces you charge for the Uber Elder arena. You charge exhausted both Shaper and Elder their own means to accumulate the abounding set of fragments bare for the final fight PoE 1 currency.
First, farm the Shaper and Elder fights. The Shaper pieces appear from the Shaper branch afterwards you aggregate the four altered Shaper Guardian fragments from Chimera, Minotaur, Phoenix, and Hydra. The Elder pieces appear from the Elder branch afterwards you accumulate the four altered Elder Guardian fragments from Eradicator, Constrictor, Enslaver, and Purifier. Defeat anniversary bang-up in their branch to acquire the fragment drops that advance to the Uber Elder encounter. Expect duplicates. The bead table is not kind, and you will generally get repeats afore you accomplishment the set.
Next, use Harvest crafting to fix alike problems. The Sacred Grove offers a ability that swaps one Shaper or Elder fragment into addition alternative at random. This bandy can about-face added copies into the missing pieces you need. Use this advantage back you accept several duplicates of one fragment. It saves you from active added abounding bang-up fights aloof to hunt a distinct missing fragment. Plan to appointment the Grove generally if you run abounding bang-up fights, back converting duplicates cuts ashen time.
Also, antithesis agriculture with trading. The barter bazaar generally moves faster than agriculture back you alone abridgement one or two fragments. If one fragment is bargain on the market, it can be faster to buy it and accumulate agriculture the others. If you accept a assemblage of duplicates alike afterwards swaps, accede affairs some. Affairs added pieces funds runs, buys bare items, and pays for any planned Harvest crafts. Learn the accepted bazaar prices so you adjudge back to buy and back to accumulate farming.
Use alternate, lower-yield sources alone as backup. Kirac mission rewards and added high-tier agreeable do not anxiously alter the capital sources, but they can sometimes add fragments or abundant currency to accomplish a targeted purchase. The best access is still to focus on Shaper and Elder guardian runs and again administer Harvest swaps and trading to ample the gaps. These added sources advice alone back you charge baby boosts rather than complete sets.
Plan a accumulated avenue for acceleration and repeatability. Run the bang-up fights you do best and aggregate fragments as you go. Use the Sacred Grove bandy back you hit alike walls. Watch the bazaar and absorb PoE 1 currency buy back it is cheaper than the time you would charge to farm addition run. This alloyed access minimizes blow and gets you to again Uber Elder attempts faster. Track which fragments you get best generally and acclimatize your runs so you farm the agreeable that tends to bead what you lack.
Users browsing this thread: 3 Guest(s)
