01-10-2024, 08:07 AM
Unlike most games, leveling up in Dark and Darker won’t increase your stats. Instead, you want to level up to buy Dark And Darker Gold gain Perk Slots. Players receive one Perk Slot at Level 1, two at Level 5, three at Level 10, and four at Level 15. These slots allow you to unlock and equip perks that will help you survive and thrive in the game.
Players have noticed the Class Training tab in Dark and Darker, but it’s currently unavailable. This tab will likely be where players can increase their stats in the future. It’s essential to keep in mind that different classes require different types of stats.
For example, if you’re a Barbarian, you’ll want to level up your raw damage or tankiness, while Wizards should build up their spell cast speed or spell damage. Rogues should put levels into their agility or strength, depending on their playstyle. If you’re a looter and escape artist, more agility is best for you. But if you prefer a more direct approach, strength will give you a stronger stabbing capability.
If you want to gain EXP quickly, there are a few things to keep in mind Darker Gold. The blue portal is worth more, as is the red portal deeper into the dungeon. You can earn even more EXP by defeating the boss near the red portal.
