12-31-2025, 05:34 AM
Arc Raiders can be challenging to new players and even experienced ones because the game mixes exploration, combat, and resource management. In general, most players want to know how to progress efficiently, complete missions, and gather the materials they need. This guide covers common questions and practical strategies based on what players usually do in the game.
How Do You Complete the Turnabout Mission?
The Turnabout mission is one of the early story missions, and it involves working with Celeste at the Spaceport. Most players find it straightforward once they understand the steps, but it helps to know what to expect.
In practice, players often combine careful movement with short bursts of combat. Rushing in tends to result in unnecessary deaths, while a slower, methodical approach usually works best.
What Are the Best Ways to Collect Gun Parts?
During missions like Turnabout, you often need to collect crafting materials such as Heavy Gun Parts and Medium Gun Parts. For example, in this mission, you will need:
Most players gather these by exploring every room and loot crate along the way. In general, enemies may drop some parts, but crates and storage areas are the main sources. Players usually prioritize Heavy Gun Parts because they are used in higher-tier weapons, while Medium Gun Parts are easier to replace and more common.
If you are looking to craft or upgrade efficiently, it’s also common to combine scavenging from missions with trading or purchasing cheap arc raiders blueprints in-game, as these blueprints often include components that save time. This approach is used by players who want to focus on combat rather than farming materials repeatedly.
How Should You Approach Combat in the Spaceport?
The Spaceport area in Turnabout is a mix of open zones and tighter corridors. In general, most players find that a balanced approach works best:
In practice, a combination of stealth, cover, and careful target selection works better than rushing through. Most experienced players adapt their loadout to the enemies in the area, swapping between heavy and medium weapons depending on what they encounter.
How Do Crafting and Upgrades Work in Practice?
Many new players are unsure how crafting materials translate to usable gear. In general, the process is straightforward:
In practice, crafting and upgrading efficiently can be the difference between struggling in higher-level missions and progressing smoothly.
What Are Common Mistakes to Avoid?
Even experienced players sometimes make predictable errors. Here are a few based on common behavior:
Avoiding these mistakes will save time and resources in the long run.
Tips for Managing Missions Efficiently
By following these practical approaches, most players find missions smoother and less frustrating.
- Go to the North Trench Tower: This is the main objective at the start of the mission. In general, you’ll want to approach carefully because enemies tend to spawn along the pathways leading to the tower. Most players suggest scouting the area first to avoid unnecessary firefights.
- Locate the Blackmail Files: Once at the tower, you need to find and upload the blackmail files to Celeste. Usually, players prioritize this task over fighting extra enemies unless they are forced into combat. The files are often in rooms that are guarded or contain small puzzles. Look around carefully and don’t rush.
- Upload to Celeste: After finding the files, the upload process is automatic once you interact with the terminal. Most players complete this quickly, but make sure the area is cleared of enemies before you start, as interruptions can cause delays.
- 2x Heavy Gun Parts
- 2x Medium Gun Parts
- Use Cover Frequently: Enemies tend to hit hard if you stay out in the open. Most players hug walls and use crates or other structures for cover while firing.
- Focus Fire: When multiple enemies appear, taking them out one by one is usually more effective than spreading damage across them.
- Watch for Patrols: Some areas have patrols that can flank you. Most players either wait for them to pass or engage them before moving forward.
- Collect Parts: As mentioned, Heavy and Medium Gun Parts are common requirements for weapon upgrades.
- Use Blueprints: Most players rely on blueprints to know exactly what to craft. Cheap arc raiders blueprints are popular because they allow players to build necessary items without overcommitting resources.
- Upgrade Strategically: Don’t upgrade every weapon at once. Most players focus on a core set of weapons that suit their playstyle and save rare materials for higher-level gear.
- Rushing Missions: Many new players rush to complete objectives and end up triggering multiple enemy spawns. Most players recommend clearing enemies gradually.
- Ignoring Material Collection: Skipping gun parts or other crafting materials slows progression. Most players collect everything in mission zones before moving on.
- Overupgrading Rare Weapons Early: Some players spend too many resources upgrading low-tier weapons. Usually, it’s better to upgrade only weapons you use frequently.
- Plan Your Route: Before entering a mission, note where objectives and materials are likely located. Most players follow a route that minimizes backtracking.
- Balance Combat and Exploration: Don’t engage every enemy immediately. In general, players decide which fights are necessary and which can be bypassed.
- Check Inventory Frequently: Keep track of your parts and upgrades. Most players adjust their crafting strategy based on what they already have to avoid wasting materials.
